Steel Pipes - Weight
The weight of carbon and alloy steel pipes - in pounds per foot:
For full table with thicker walls - rotate the screen!
Outside Diameter OD (in) | Weight (lb/ft) | |||||||||||||||
Wall Thickness (in) | ||||||||||||||||
0.050 | 0.095 | 0.150 | 0.200 | 0.250 | 0.300 | 0.360 | 0.400 | 0.460 | 0.500 | 0.625 | 0.750 | 0.875 | 1.000 | 1.125 | 1.250 | |
1/2 | 0.2403 | 0.4109 | 0.5607 | |||||||||||||
3/4 | 0.3738 | 0.6646 | 0.9612 | 1.175 | 1.335 | |||||||||||
1 | 0.5073 | 0.9182 | 1.362 | 1.709 | 2.003 | 2.243 | 2.461 | |||||||||
1 1/4 | 0.6408 | 1.172 | 1.762 | 2.243 | 2.670 | 3.044 | 3.422 | 3.631 | ||||||||
1 1/2 | 0.7743 | 1.426 | 2.163 | 2.777 | 3.338 | 3.845 | 4.383 | 4.699 | 5.109 | 5.340 | ||||||
2 | 1.041 | 1.933 | 2.964 | 3.845 | 4.673 | 5.447 | 6.305 | 6.835 | 7.566 | 8.010 | 9.178 | 10.01 | ||||
2 1/2 | 1.308 | 2.440 | 3.765 | 4.913 | 6.008 | 7.049 | 8.228 | 8.971 | 10.02 | 10.68 | 12.52 | 14.02 | 15.19 | |||
3 | 1.575 | 2.947 | 4.566 | 5.981 | 7.343 | 8.651 | 10.15 | 11.11 | 12.48 | 13.35 | 15.85 | 18.02 | 19.86 | 21.36 | ||
4 | 2.109 | 3.962 | 6.168 | 8.117 | 10.01 | 11.85 | 14.00 | 15.38 | 17.39 | 18.69 | 22.53 | 26.03 | 29.20 | 32.04 | 34.54 | |
5 | 2.643 | 4.977 | 7.770 | 10.25 | 12.68 | 15.06 | 17.84 | 19.65 | 22.30 | 24.03 | 29.20 | 34.04 | 38.55 | 42.72 | 45.56 | 50.06 |
6 | 5.991 | 9.372 | 12.39 | 15.35 | 18.26 | 21.68 | 23.92 | 27.22 | 29.37 | 35.88 | 42.05 | 47.89 | 53.40 | 58.57 | 63.41 | |
8 | 16.66 | 20.69 | 24.67 | 29.37 | 32.47 | 37.04 | 40.05 | 49.23 | 58.07 | 66.58 | 74.76 | 82.60 | 90.11 | |||
10 | 26.03 | 31.08 | 37.06 | 41.01 | 46.87 | 50.73 | 62.58 | 74.09 | 85.27 | 96.12 | 106.6 | 116.8 | ||||
- 1 lb/ft = 1.49 kg/m
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipe - Dimensions
ASTM A53 B Carbon Steel Pipes - Allowable Pressure vs. Schedule and Size
Maximum working pressure of carbon steel pipe at temperature 400oF.
EN 10241 - Steel Threaded Pipe Fittings
EN 10241 specifies requirements for screw threaded fittings.
Ice Loaded Pipelines
Ice coat weight on horizontal pipe lines.
Pipe Weight Calculator
Steel Flats - Weights
Steel Pipes - Bundling Schedules Length and Weight
Bundling schedules for standard weight and extra strong steel pipes.
Steel Plate Weight Guide: Calculator & Data Table
Welded Steel Pipes - Weights
Nominal weights of welded steel pipes ranging 26 - 60 inches.
