A solar heater is made like a coil with 20 mm pipe inside a 1 m x 1 m window frame. The coil is done like a doughnut with an outer radius of 0.5 m and an inner radius of 0.1 m due to the bending limits of the pipe. If the coil is with no space between the pipes the number of turns can therefore be calculated as
n = (0.5 m) / (0.02 m)
= 25
The length of the water pipe in the solar heater can be calculated as
L = 3.14 (25) ((1 m) - (0.2 m)) / 2
= 31.4 m
