The ANSI/ASME B1.5 ACME Screw Threads Standard provides
Centralizing Acme threads have limited clearance at the major diameters of both the internal and external threads and are used extensively for feed screws. Restricted clearance enables a bearing at the major diameter of the thread to preserve alignment of the thread axis preventing wedging on the flanks and part sagging.
Thread data - metric, unified, ACME and others.
Dimensions of ISO metric trapezoidal screw threads.
