Distance between Control Points (m, mm, ft, in ...) | |
A - B | |
Distance between Control Points and Measure Points (m, mm, ft, in ...) | |||
A | B | Below A - B | |
1 | |||
2 | |||
3 | |||
4 | |||
5 | |||
6 | |||
7 | |||
8 | |||
9 | |||
Copy the red, green and blue coordinates from the textbox below and paste them into the input box in the free Engineering ToolBox extension - "Lines made from Custom Points".
Note! the Engineering ToolBox plugin window must be opened from within Sketchup before pasting the data.
x, y, z |
The values above are plain Cartesian x,y (and z) coordinates that can be transferred manually to almost any type of CAD system.
Tip! In Sketchup - add a "face" to the plot area and use the push/pull tool to make a 3D model of the room or object you are surveying.
The svg file format can be used with most drawing, cad and web based applications.
Copy the SVG code from the window that opens below and paste it to your drawing or document. Note - due to the svg format all coordinates are made positive. Coordinates are offset with the smallest x and y values.
2D and 3D engineering drawing tools.
Convert between units of area.
Convert builder's measurements to surveyor's measurements.
Calculate the maximum number of circles within a rectangle - can be used to calculate the numbers of pipes or wires in a conduit or similar.
Distance between two points in a three dimension x, y and z coordinate system - online calculator.
Commonly used blueprint drawing scales.
Standard metric drawing sheet sizes.
Radius and side lengths of equal areas, circles and squares.
Convert lengths areas between different mapping scales.
Convert between Cartesian and Polar coordinates.
A rectangle is square if the lengths of both diagonals are equal.
US architectural drawing sizes and formats.
US engineering drawing sizes based on ANSI/ASME Y14.1.
