Drawings - Standard Metric Sizes
The ISO A0 size is defined as having an area of one square meter. Each smaller sheet size is exactly half the area of the previous size
- an A0 sheet cut in half gives two A1 sheets
- an A1 sheet in half you get two A2 sheets
| Designation | Size of sheet | Size of frame | ||
| A mm | B mm | C mm | D mm | |
| A0 | 841 | 1189 | 791 | 1139 |
| A1 | 594 | 841 | 554 | 804 |
| A2 | 420 | 594 | 380 | 554 |
| A3 | 297 | 420 | 267 | 390 |
| A4 | 210 | 297 | 180 | 267 |
| A5 | 148 | 210 | ||
| A6 | 105 | 148 | ||
• Drawing Tools
2D and 3D engineering drawing tools.
Area Survey App
Online app that can be used to make an exact plot of a surveyed area - like a room, a property or any 2D shape.
Blueprint Letters
Letters commonly used to differentiate blueprint drawings.
Building Tolerances
Typical tolerances for floors, walls, columns and more.
Drawing Scales
Commonly used blueprint drawing scales.
Golden Section
Golden Section also called the Golden Mean.
Lengths and Areas vs. Mapping Scales
Convert lengths areas between different mapping scales.
Paper Drafting Sizes - Comparing ISO and U.S. Drawing Sheets
ISO vs. U.S. and Canadian drawing sheets.
Paper Drafting Sizes - ISO 216 series A, B and C
ISO 216 A, B and C drawing series - dimensions of regular, oversized and envelope sheets.
Paper Sizes - commonly used in U.S. Offices
Office paper sizes as Letter, Legal, Tabloid and more.
Paper Sizes - Imperial
Printing and drawing papers sizes.
U.S. Standard Architectural Drawing Sizes
US architectural drawing sizes and formats.
