Paper Drafting Sizes - ISO 216 series A, B and C
ISO 216 "Writing paper and certain classes of printed matter; Trimmed sizes; A and B series" specifies international standard (ISO) paper sizes, used in most countries in the world today with three series of paper sizes: A, B and C. Series C is primarily used for envelopes.
ISO A Series
The ISO A series of sheet sizes is based on a constant width to length ratio of 1 : √2 (rounded to the nearest millimeter). The A0 size is defined as having an area of one square meter (1 m2). Paper weights is expressed in grams per square meter.
Each smaller sheet size is exactly half the area of the previous size.
| ISO A Series | Size | |
| (mm) | (inches) | |
| A0 | 841 x 1189 | 33.11 x 46.81 |
| A1 | 594 x 841 | 23.39 x 33.1 |
| A2 | 420 x 594 | 16.54 x 23.29 |
| A3 | 297 x 420 | 11.69 x 16.54 |
| A4 | 210 x 297 | 8.27 x 11.69 |
| A5 | 148 x 210 | 5.83 x 8.27 |
| A6 | 105 x 148 | |
| A7 | 74×105 | |
| A8 | 52 x 74 | |
| A9 | 37 x 52 | |
| A10 | 26 x 37 | |
| A11 | 18 x 26 | |
| A12 | 13 x 18 | |
ISO 216 does not define sizes larger than A0 or B0. With the German standard DIN 476 "Trimmed sizes of paper" the sizes can be expanded by using a factor in front of the size:
- 2A0 is twice the size of A0
- 4A0 is four time the size of A0
Oversized ISO A Sheets
Oversized sheets are used when it is desirable to give extra protection to the drawing sheets by providing a binding or trimming margin.
| ISO A Series | Size (mm) |
| RA0 | 860 x 1220 |
| RA1 | 610 x 860 |
| RA2 | 430 x 610 |
| RA3 | 305 x 430 |
| RA4 | 215 x 305 |
| RA5 | 153 x 215 |
ISO B Series
The ISO B series are geometric means between the A series and defined to satisfy the requirements of sizes between the A series sizes. For example, B1 is a geometric mean between A1 and A0.
| ISO B Series | Size | |
| (mm) | (inches) | |
| B0 | 1000 x 1414 | 39.37 x 55.67 |
| B1 | 707×1000 | 27.83 x 39.37 |
| B2 | 500 x 707 | 19.68 x 27.83 |
| B3 | 353 x 500 | 13.90 x 19.68 |
| B4 | 250 x 353 | 9.84 x 13.90 |
| B5 | 176 x 250 | 6.93 x 9.84 |
| B6 | 125 x 176 | |
| B7 | 88 x 125 | |
| B8 | 62 x 88 | |
| B9 | 44 x 62 | |
| B10 | 31 x 44 | |
| B11 | 22 x 31 | |
| B12 | 15 x 22 | |
ISO C Series - Envelopes
Series C is primarily used for envelopes. The C series formats are geometric means between the B series format with the same number and the A series format with the same number - C2 is the geometric mean between B2 and A2.
| ISO C Series Envelopes | Size | |
| (mm) | (inches) | |
| C0 | 917 x 1297 | 36.00 x 51.20 |
| C1 | 648 x 917 | 25.60 x 36.00 |
| C2 | 458 x 648 | 18.00 x 25.60 |
| C3 | 324 x 458 | 12.80 x 18.00 |
| C4 | 229 x 324 | 9.00 x 12.80 |
| C5 | 162 x 229 | 6.40 x 9.0 |
| C6 | 114 x 162 | |
| C7 | 81 x 114 | |
| C8 | 57 x 81 |
Commonly Used Formats |
An A4 page will fit into a C4 envelope, A5 will fit into a C5 envelope and so on.
Other Commonly Used Formats
| Name | Size (mm) |
| Letter | 215.9 x 279.4 |
| Legal | 215.9 x 355.6 |
| Executive | 190.5 x 254.0 |
| C5E | 163.0 x 229.0 |
| Comm10 | 105.0 x 241.0 |
| DLE | 110.0 x 220.0 |
| Folio | 210.0 x 330.0 |
| Ledger | 432.0 x 279.0 |
| Tabloid | 279.0 x 432.0 |
• Drawing Tools
2D and 3D engineering drawing tools.
Drawing Scales
Commonly used blueprint drawing scales.
Drawings - Standard Metric Sizes
Standard metric drawing sheet sizes.
Golden Section
Golden Section also called the Golden Mean.
Lengths and Areas vs. Mapping Scales
Convert lengths areas between different mapping scales.
Paper Drafting Sizes - Comparing ISO and U.S. Drawing Sheets
ISO vs. U.S. and Canadian drawing sheets.
Paper Sizes - commonly used in U.S. Offices
Office paper sizes as Letter, Legal, Tabloid and more.
Paper Sizes - Imperial
Printing and drawing papers sizes.
U.S. Standard Architectural Drawing Sizes
US architectural drawing sizes and formats.
