Solving Quadratic Equation with One Unknown
The quadratic equation can be expressed as
a x2 + b x + c = 0 (1)
which can be solved for the two alternatives of x as
x1,2 = (-b ± (b2 - 4 a c)1/2) / (2 a) (2)
Example - Solving Quadratic Equation
If
a = 1
b = 6
c = 5
then the two alternatives for x can be calculated as
x1 = (-6 + (62 - 4 1 5)1/2) / (2 1)
= -1
x2 = (-6 - (62 - 4 1 5)1/2) / (2 1)
= -5
• Mathematics
Algebraic Expressions
Principal algebraic expressions formulas.
Circles within a Rectangle - Calculator
Calculate the maximum number of circles within a rectangle - can be used to calculate the numbers of pipes or wires in a conduit or similar.
Discrete Data Sets and their Mean, Median and Mode Values
Calculate the arithmetic mean, median and modal values from discrete data sets.
Logarithms
The rules of logarithms - log10 and loge for numbers ranging 1 to 1000.
Numbers - Standard Form, Scientific and Engineering Notation
The difference between standard, scientific and engineering number notation.
Prime Numbers
Prime numbers up to 1000.
Solving Equations of the First Degree with One Unknown
Equations with one unknown.
Solving First Degree Equations with Two Unknowns
Online calculator and solbing procedure for two equations with two unknowns.
Square, Cube, Square Root and Cubic Root Calculator
Calculate square, cube, square root and cubic root of numbers. Values tabulated for numbers ranging 1 to 100.
