Triangle
Centroid of Triangle
The centroid of a triangle in a co-ordinate system can be expressed as
xs = (x1 + x2 + x3) / 3 (1)
ys = (y1 + y2 + y3) / 3 (1b)
Area of Triangle
The area of the triangle can be expressed as
A = ((x1 y2 - x2 y1) + (x2 y3 - x3 y2) + (x3 y1 - x1 y3)) / 2 (2)
Triangle Calculator
Point | x | y |
1 | ||
2 | ||
3 | ||
Centroid | ||
Area |
Example - Centroid and Area of Triangle
The centroid of a triangle with points P1 (0,0), P2(1,1) and P3 (1,0.5) can be calculated as
xs = (0 + 1 + 1) / 3
= 0.67
ys = (0 + 1 + 0.5) / 3
= 0.5
The area can be calculated as
A = ((0 1 - 1 0) + (1 0.5 - 1 1) + (1 0 - 0 0.5)) / 2
= 0.25
• Mathematics
Cartesian Coordinate System - Distance and Intermediate Position Between Two Points
Distance and intermediate position between two point in a cartesian x and y coordinate system.
Center of Gravity
A body and the center of gravity.
Complex Numbers
Complex numbers are used in alternating current theory and mechanical vector analysis.
Law of Cosines
One side of a triangle when the opposite angle and two sides are known.
Law of Sines
Calculate the angles in a generic triangle.
Law of Tangents
Triangles and law of tangents.
Oblique Triangle
Calculate oblique triangles.
Polar vs. Cartesian Coordinates
Convert between Cartesian and Polar coordinates.
Pythagorean Theorem
Verifying square corners.
Radians vs. Degrees - Definition and Conversions
Right Angled Triangle
Right angled triangle equations.
