Law of Sines
The "Law of Sines" can be used to calculate the angles of a triangle.
The "Law of Sines" can be expressed as
$$  {a  \over sin A } = {b  \over sin B } = {c  \over sin C }   \tag{1}$$
a, b and c = length of sides in triangle (m, ft ...)
A, B and C = angles in the triangle (degrees)
Law of Sines Calculator
Eq. 1 can be modified to
$$  a = {b sin A \over sin B }  =  {c sin A \over sin C } \tag{1a}$$
$$  b = {a sin B \over sin A }  =  {c sin B \over sin C } \tag{1b}$$
$$  c = {a sin C \over sin A }  =  {b sin C \over sin B } \tag{1c}$$
This expression can also be handy:
$$  sin \frac{1}{2}A = \sqrt{{(s - b)(s - c) \over b c }}     \tag{2}$$
$$  s = \frac{1}{2}(a + b  + c)     \tag{3}$$
Mathematics
Exponents - Powers and Roots
The laws of fractional and integer exponents.
Factorials
The product of all positive integers.
Fractions
Law of fractions
Law of Cosines
One side of a triangle when the opposite angle and two sides are known.
Law of Tangents
Triangles and law of tangents.
Pythagorean Theorem
Verifying square corners.
Right Angled Triangle
Right angled triangle equations.
Squaring with Diagonal Measurements
A rectangle is square if the lengths of both diagonals are equal.
Standard Differentials and Integrals
Equations for differentials and integrals.
Taylor Series
Function as an infinite sum of terms.
Triangle
Triangle analytical geometry.
