am/n = (am)1/n = (a1/n)m (8)
p (a)1/n ± q (a)1/n = (p ± q) a1/n (9)
(a b)1/n = a1/n b1/n (10)
a1/n / b1/n = (a / b)1/n (11)
(amx)1/nx = (am)1/n (12)
(-a)1/2 = i a1/2 (13)
i = imaginary number
The SI-system, unit converters, physical constants, drawing scales and more.
Principal algebraic expressions formulas.
Prefix names used for multiples and submultiples units.
Derivatives and differentiation expressions.
Law of fractions
Areas, diagonals and more - of geometric figures like rectangles, triangles, trapezoids ..
One side of a triangle when the opposite angle and two sides are known.
Calculate the angles in a generic triangle.
The rules of logarithms - log10 and loge for numbers ranging 1 to 1000.
Calculate square, cube, square root and cubic root. Values tabulated for numbers ranging 1 to 100.
The difference between standard, scientific and engineering number notation.
