Ice - Properties
- Youngs modulus of elasticity E (GPa): 9.1
- Fracture of toughness Kc (MPa m1/2): 0.12
- Ultimate tensile strength σu (MPa): 1
- Compressive strength σc (MPa): 6
Ice - Safe Load vs. Thickness
Safe loads vs. thickness for clear and solid ice.
Ice - Thermal Properties
Thermal and thermodynamic properties of ice like density, thermal conductivity and specific heat at temperatures from 0 to -100 oC.
Ice Loaded Pipelines
Ice coat weight on horizontal pipe lines.
Saturated Ice and Steam - Thermodynamic Properties
Thermodynamic properties of saturated ice and steam - specific volume, enthalpy and entropy.
