Ice - Safe Load vs. Thickness
Safe loads for clear solid ice are indicated below:
Ice - Safe Loads vs. Thickness
Thickness of IceLoad or Activity
incm
< 1 3/4 < 4.5 STAY OFF
1 3/4 4.5 One person cross county skiing
2 5 One person on foot or skates
4 7.5 Snowmobile or smaller ATV, groups of people walking in a single line
7 17.5 A small car
8 20 A 2 1/2 tons truck
9 22.5 A 3 1/2 tons truck
10 25 A 7 - 8 tons truck
Note that ice strength is influenced by many factors
  • age - newer black ice is stronger than old milky
  • distance to shore - ice close to shore is weaker than ice farther out
  • river outlets and inlets - ice close to outlets and inlets is weaker
  • obstructions like rocks, trees and plants
  • water currents
  • cover of snow
 This information must only be used as a general guide - KEEP OFF the ice if you are not absolutely sure.
Material Properties
Friction - Coefficients for Common Materials and Surfaces
Find friction coefficients for various material combinations, including static and kinetic friction values. Useful for engineering, physics, and mechanical design applications.
Ice - Properties
Properties like Youngs modulus, tensile strength, compressive strength and fracture of toughness for ice.
Ice - Thermal Properties
Thermal and thermodynamic properties of ice like density, thermal conductivity and specific heat at temperatures from 0 to -100 oC.
Ice Loaded Pipelines
Ice coat weight on horizontal pipe lines.
