Wet Steam - Enthalpy
The actual enthalpy of evaporated wet steam is the product of the dryness fraction - ζ - and the specific enthalpy - hs - from the steam tables. Wet steam has less usable heat energy than dry saturated steam.
ht = hs ζ + (1 - ζ) hw (1)
ht= enthalpy of wet steam (kJ/kg, Btu/lb)
hs = enthalpy of steam (kJ/kg, Btu/lb)
ζ = dryness fraction
hw= enthalpy of saturated water or condensate (kJ/kg, Btu/lb)
The dryness fraction can be expressed as
ζ = ws / (ww + ws) (2)
ww = mass of water (kg, lb)
ws = mass of steam (kg, lb)
• Thermodynamics
Thermodynamics of steam and condensate systems.
2nd Law of Thermodynamics
Entropy and disorder.
Flash Steam Generation - Fundamental Physics
Tutorial to the basic physics behind flash steam generation
Saturated Steam - Properties - Imperial Units
Saturated Steam - Properties for Pressure in Bar
Saturated Steam Table with properties like boiling point, specific volume, density, specific enthalpy, specific heat and latent heat of vaporization.
Standard State and Enthalpy of Formation, Gibbs Free Energy of Formation, Entropy and Heat Capacity
Definition and explanation of the terms standard state and standard enthalpy of formation, with listing of values for standard enthalpy and Gibbs free energy of formation, as well as standard entropy and molar heat capacity, of 370 inorganic compounds.
Steam - Enthalpy and Entropy Diagram
An enthalpy and entropy chart for steam
Steam and Vapor Enthalpy
Vapor and steam enthalpy, specific enthalpy of saturated liquid, saturated vapor and superheated vapor.
Steam Entropy
Basic steam thermodynamics - entropy diagram.
Superheated Steam - Enthalpy
Enthalpy of steam superheated to temperatures above it's boiling point.
Thermodynamic Key Values Internationally Agreed
Internationally agreed, internally consistent, values for the thermodynamic properties (standard enthalpy of formation, entropy and [H°(298)-H°(0)]) of key chemical substances.
Vapor and Steam
An introduction to vapor and steam.
Water-Steam Mollier Diagram
Wet Steam - Quality vs. Dryness Fractions
Introduction and definition of steam quality and dryness fraction including calculating wet steam enthalpy and specific volume.
Wet Steam - Specific Volume
Wet steam and specific volume.
