Wet Steam - Specific Volume
The droplets of water in wet steam occupies negligible space in the steam and the specific volume of wet steam will be reduced according the dryness fraction:
v = vs ζ                            (1)
v= specific volume of wet steam (m3/kg, ft3/lb)
vs= specific volume of the dry steam (m3/kg, ft3/lb)
ζ  = dryness fraction
Thermodynamics
Steam Entropy
Basic steam thermodynamics - entropy diagram.
Thermodynamic Properties of Saturated Steam: Data & Charts in Bar
Saturated Steam Table with properties like boiling point, specific volume, density, specific enthalpy, specific heat and latent heat of vaporization.
Vapor and Steam
An introduction to vapor and steam.
Water-Steam Mollier Diagram
Wet Steam - Enthalpy
Wet Steam - Quality vs. Dryness Fractions
Introduction and definition of steam quality and dryness fraction including calculating wet steam enthalpy and specific volume.
