Two systems are in thermal equilibrium if they are at same temperature."
The law is important for the mathematical formulation of thermodynamics where the relation of thermal equilibrium is the basis for an equivalence relation.
Entropy and disorder.
The entropy of a substance is zero if the absolute temperature is zero.
