Steam Heating Systems - Classifications
Steam is commonly used to distribute heat from a boiler to consumers like heat exchangers, process equipment etc. Steam is also used for heating buildings.
Steam systems can be classified by pressure, method for returning condensate and/or pipe lay out.
Classification of Steam Systems by Pressure
Its common to classify steam systems as
- High pressure above 20 kN/m2 (3 lb/in2)
- Low pressure up to 20 kN/m2 (3 lb/in2)
- Vacuum
Classification of Steam Systems by Method of Condensate Return
Steam systems can be classified as
- Gravity
- Mechanical
Classification of Steam Systems by Pipe Lay Out
Steam systems can be classified by pipe scheme:
- One pipe or two pipe
- Up-feed or down-feed
• Heat Loss and Insulation
Steam and condensate pipes - heat loss uninsulated and insulated pipes, insulation thickness and more.
• Pipe Sizing
Sizing of steam and condensate pipe lines - pressure loss, recommended velocity, capacity and more.
• Steam and Condensate
Heating Systems - Steam and Condensate Loads
Saturated Steam - Properties - Imperial Units
Saturated Steam - Properties for Pressure in Bar
Saturated Steam Table with properties like boiling point, specific volume, density, specific enthalpy, specific heat and latent heat of vaporization.
Steam & Condensate Equations
Steam consumption and condensate generation when heating liquid or gas flows
Steam Heating Air
