Copper Tubes - Heat Carrying Capacities
Copper tubes are often used in hot water heating systems, especially to connect heating elements like radiators, fan units and similar to the main pipe lines.
Download and print Copper Tubes - Heat Carrying Capacities diagram
The table below can be used to estimate hot water heat carrying capacity in copper tubes type L:
Nominal tube size (inch) | Heat Carrying Capacity (103Btu/hr) 1) | |||||||||||
Friction Head (10-3 inH2O/ft of tube) | ||||||||||||
920 | 600 | 480 | 360 | 300 | 240 | 180 | 150 | 120 | 90 | 75 | 60 | |
3/8 | 10 | 9 | 8 | 7 | 6 | 5.5 | 4.5 | 4 | 3.5 | 3 | 3 | 2.5 |
1/2 | 20 | 18 | 16 | 13.5 | 12 | 11 | 9 | 8 | 7 | 6 | 5 | 5 |
5/8 | 36 | 30 | 26 | 22 | 20 | 18 | 15 | 13 | 12 | 10 | 9 | 8 |
3/4 | 51 | 46 | 40 | 34 | 31 | 28 | 23 | 21 | 18 | 15 | 14 | 12 |
1 | 104 | 94 | 82 | 70 | 63 | 56 | 47 | 42 | 37 | 32 | 28 | 25 |
1 1/4 | 185 | 169 | 149 | 125 | 112 | 100 | 84 | 75 | 66 | 56 | 50 | 44 |
1 1/2 | 300 | 270 | 235 | 200 | 180 | 160 | 134 | 120 | 105 | 90 | 81 | 71 |
2 | 625 | 560 | 495 | 420 | 375 | 335 | 258 | 250 | 200 | 188 | 170 | 150 |
2 1/2 | 1130 | 1010 | 890 | 750 | 680 | 600 | 500 | 450 | 395 | 335 | 305 | 270 |
3 | 1840 | 1650 | 1450 | 1210 | 1100 | 980 | 820 | 740 | 650 | 550 | 490 | 420 |
3 1/2 | 2750 | 2480 | 2170 | 1840 | 1650 | 1450 | 1210 | 1100 | 980 | 820 | 740 | 650 |
4 | 3900 | 3500 | 3100 | 2600 | 2350 | 2090 | 1760 | 1580 | 1390 | 1180 | 1080 | 950 |
1) The table is designed for temperature drop 20 oF (11 oC) in radiators and heating elements. For other temperature drops the values must be changed accordingly. With temperature drop 10 oF (5.5 oC) - multiply the capacities with 0.5.
- 1 in (inch) = 25.4 mm
• Heating Systems
ASTM B302 - Threadless Copper Pipes - Dimensions
ASTM B42 - Seamless Copper Pipes - Dimensions
ASTM B837 - Seamless Copper Tubes for Natural Gas and Liquified Petroleum - Dimensions
ASTM B88 - Seamless Copper Water Tubes - Dimensions
ASTM B88M - Seamless Copper Water Tubes - Metric Dimensions
Water and gas copper tubes according ASTM B88M - type K, L and M - metric units.
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper Tubes - Heat Losses
Heat loss from uninsulated copper tubes vs. temperature differences between tube and air.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
Copper Tubes Type K, L and M - Working Pressures vs. Size
EN 1057 Copper Tubes for Water and Gas in Sanitary and Heating Applications - Dimensions
Dimensions of EN 1057 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications.
EN 12449 - Copper and Copper Alloys - Seamless, Round Tubes for General Purposes - Dimensions
Dimensions of copper tubes according EN 12449.
Hot Water Heating System Online Design Application
Insulated Copper Tubes - Heat Loss
Heat loss to surrounding air from insulated copper tubes.
Solder Joints - Pressure Ratings vs. Temperature
Solder joints and their pressure ratings according ASME B16.18.
