Air Ducts - Sizing
Air flow, air velocity and required air-duct area:
- 1 ft/min = 5.08x10-3 m/s
- 1 ft3/min = 1.7 m3/h = 0.47 l/s
- 1 ft2 = 0.0929 m2 = 144 in2
- free apps for offline use on mobile devices
Insert ducts to your Sketchup model with the Engineering ToolBox Sketchup Extension
• HVAC Systems
Heating, ventilation and air conditioning systems - design and dimensions.
• Ventilation
Air Duct Components - Minor Dynamic Loss Coefficients
Minor loss (pressure or head loss) coefficients for air duct components.
Air Duct Velocities
Typical air duct velocities in applications like ventilation systems or compressed air systems.
A major friction loss diagram for air ducts - SI units.
Air Ducts - Velocity Diagram
Air flow volume, duct size, velocity and dynamic pressure.
Circular Ducts - Dimensions
Standard size of circular ventilation air ducts.
Duct Velocity
Calculate velocities in circular and rectangular ducts - imperial and SI-units - online calculator.
Ducts or Pipes through Steel Joists - Maximum Sizes
Maximum sizes of ducts or pipes through K series joists.
