Circular Ducts - Dimensions
Circular Ducts Dimensions - Metric Units
Common circular ductwork sizes used in air handling ventilation systems:
| Nominal Diameter (mm) | Outside Diameter (mm) | Inside Diameter (mm) |
| 63 | 63 - 63.5 | 61.8 - 62.3 |
| 80 | 80 - 80.5 | 78.8 - 79.3 |
| 100 | 100 - 100.5 | 98.8 - 99.3 |
| 125 | 125 - 125.5 | 123.8 - 124.3 |
| 160 | 160 - 160.6 | 158.7 - 159.3 |
| 200 | 200 - 200.7 | 198.6 - 199.3 |
| 250 | 250 - 250.8 | 248.5 - 249.3 |
| 315 | 315 - 315.9 | 313.4 - 314.3 |
| 400 | 400 - 401.0 | 398.3 - 399.3 |
| 500 | 500 - 501.1 | 498.2 - 499.3 |
| 630 | 630 - 631.2 | 628.1 - 629.3 |
| 800 | 800 - 801.6 | 798.0 - 799.3 |
| 1000 | 1000 - 1002.0 | 997.9 - 999.3 |
| 1250 | 1250 - 1252.5 | 1247.8 - 1249.3 |
Circular Galvanized Steel Ducts - Areas and Weights - Imperial Units
| Diameter (inches) | Surface Area (ft2/ft) | Gage | ||
| 26 | 24 | 22 | ||
| Weight (lbs/ft) | ||||
| 4 | 1.05 | 1.02 | 1.36 | 1.59 |
| 5 | 1.31 | 1.25 | 1.67 | 1.95 |
| 6 | 1.57 | 1.49 | 1.98 | 2.32 |
| 7 | 1.83 | 1.72 | 2.30 | 2.69 |
| 8 | 2.09 | 1.96 | 2.61 | 3.06 |
| 9 | 2.36 | 2.20 | 2.93 | 3.42 |
| 10 | 2.62 | 2.51 | 3.34 | 3.91 |
| 11 | 2.88 | 2.74 | 3.66 | 4.28 |
| 12 | 3.14 | 2.98 | 3.97 | 4.64 |
| 13 | 3.40 | 3.21 | 4.28 | 5.01 |
| 14 | 3.67 | 3.45 | 4.60 | 5.38 |
| 15 | 3.93 | 3.68 | 4.91 | 5.75 |
| 16 | 4.19 | 3.92 | 5.23 | 6.12 |
| 17 | 4.45 | 4.16 | 5.54 | 6.48 |
| 18 | 4.72 | 4.39 | 5.85 | 6.85 |
| 19 | 4.98 | 4.63 | 6.17 | 7.22 |
| 20 | 5.24 | 4.94 | 6.58 | 7.70 |
| 21 | 5.50 | 5.18 | 6.90 | 8.07 |
| 22 | 5.75 | 5.41 | 7.21 | 8.44 |
| 23 | 6.02 | 5.64 | 7.53 | 8.80 |
| 24 | 6.28 | 5.88 | 7.84 | 9.17 |
| 25 | 6.54 | 6.12 | 8.15 | 9.54 |
| 26 | 6.80 | 6.35 | 8.47 | 9.91 |
| 27 | 7.07 | 8.78 | 10.27 | 12.47 |
| 28 | 7.33 | 9.10 | 10.64 | 12.92 |
| 29 | 7.59 | 9.41 | 11.01 | 13.36 |
| 30 | 7.85 | 9.83 | 11.50 | 13.95 |
| 31 | 8.11 | 10.14 | 11.86 | 14.40 |
| 32 | 8.38 | 10.45 | 12.23 | 14.84 |
| 33 | 8.65 | 10.77 | 12.67 | 15.29 |
| 34 | 8.91 | 11.08 | 12.96 | 15.75 |
| 35 | 9.17 | 11.40 | 13.33 | 16.18 |
| 36 | 9.43 | 11.71 | 13.70 | 16.63 |
| 37 | 9.69 | 12.02 | 14.07 | 17.07 |
| 38 | 9.95 | 12.34 | 14.44 | 17.52 |
| 39 | 10.21 | 12.65 | 14.80 | 17.97 |
| 40 | 10.47 | 13.07 | 15.29 | 18.55 |
| 41 | 10.73 | 13.39 | 15.66 | 19.00 |
| 42 | 10.99 | 13.70 | 16.02 | 19.45 |
| 43 | 11.26 | 14.01 | 16.39 | 19.89 |
| 44 | 11.52 | 14.32 | 16.76 | 20.34 |
• Ventilation Systems
A major friction loss diagram for air ducts - SI units.
Air Ducts - Sizing
Required duct area vs. air flow.
Air Ducts - Velocity Diagram
Air flow volume, duct size, velocity and dynamic pressure.
The equal friction method for sizing air ducts is easy and straightforward to use.
Duct Velocity
Calculate velocities in circular and rectangular ducts - imperial and SI-units - online calculator.
Ducts - Cross-Sectional Area vs. Diameter
Circular ducts sross-sectional areas.
Ducts or Pipes through Steel Joists - Maximum Sizes
Maximum sizes of ducts or pipes through K series joists.
Rectangular Air Ducts - Velocity Diagram
Velocity diagram for rectangular air ducts - metric units.
Spiral Ducts - Dimensions
Standard dimensions of spiral ducts - Imperial units.
Velocity Classification of Ventilation Ducts
Recommended air velocities in ventilation ducts
