- free apps for offline use on mobile devices
If the exhaust outlet is in a wall or with a flange the evacuation efficiency is improved and can be expressed as
vc = 1.33 vo A / (A + 10 x2)
= 1.33 q / (A + 10 x2) (3)
The calculator above can be used if volume is multiplied with 1.33. Use of exhaust hoods improves the evacuation efficiency further.
Calculate velocities in circular and rectangular ducts - imperial and SI-units - online calculator.
Capture velocities to avoid pollution products from galvanic baths, spray painting boxes and more contaminating the surrounding room and environment.
Sizing of exhaust hoods - air volume flow and capture velocities - online exhaust hood calculator.
