speed
Process Baths | Required Capture Velocity - v1 - | |
(m/s) | (fpm) | |
Hardening | 0.4 | 80 |
Stain, cold | 0.3 | 60 |
Stain, hot | 0.5 | 100 |
De-fating | 0.3 | 60 |
Galvanic, chrome or cadmium | 0.4 | 80 |
Water, not boiling | 0.2 | 40 |
Water, boiling | 0.4 | 80 |
Sizing of exhaust hoods - air volume flow and capture velocities - online exhaust hood calculator.
Capturing air velocity in front of an exhaust outlet - online exhaust outlet velocity calculator.
