The content of sucrose - Brix scale vs. Specific Gravity and Plato - used in the sugar, fruit juice and wine making industry.
Specific heat of common food and foodstuff like apples, bass, beef, pork and many more.
Bulk densities of some common food products like grain, corn, barley, sugar and more.
Mixtures vs. solutions vs. suspensions.
The amount of a solute that can be dissolved in a solvent.
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
Solubility of sugar in water.
