Potential Energy - Hydropower
When a body of mass is elevated against the gravitational force - the increase in it's potential energy can be calculated as
Ep = Fg Δh
= m ag Δh (1)
Fg = gravitational force ( weight) acting on the body (N, lbf)
Ep = potential energy (J, ft lb)
m = mass of body (kg, slugs)
ag = acceleration of gravity on earth (9.81 m/s2, 32.17405 ft/s2)
Δh = change in elevation (m, ft)
Example - Potential Energy of Elevated Body - in SI units
A body of 1000 kg is elevated 10 m. The change in potential energy can be calculated as
Ep = (1000 kg) (9.81 m/s2) (10 m)
= 98100 J
= 98 kJ
= 0.027 kWh
Example - Potential Energy of Elevated Body - in Imperial units
A body with weight (force) 500 lbf is elevated 30 ft. The change in potential energy can be calculated as
Ep = ( 500 lbf ) (30 m)
= 15000 ft lb
A body with mass 15 slugs is elevated 30 ft. The change in potential energy can be calculated as
Ep = ( 15 slugs) ( 32.17405 ft/s2<) (30 m)
= 14478 ft lb
Potential Energy in a Tank or a Reservoir - Spreadsheet Calculator
You can estimate potential elevation energy (hydropower) in a tank or a reservoir by dividing the volume in horizontal slices and calculate the elevation energy for each slice - as it is done in the spreadsheet calculator below:
You can copy the spreadsheet to your Google Drive or to your local drive if you want to use it as a template for your own calculations.
• Dynamics
• Mechanics
Energy
Energy is the capacity to do work.
Energy Storage Density
Energy density - by weight and volume - for some ways to store energy
Heat, Work and Energy
Heat vs. work vs. energy.
Hydropower
Power potential vs. head and flow rate.
Kinetic Energy
Energy possessed by an object's motion is kinetic energy.
The Mechanical Energy Equation compared to the Extended Bernoulli Equation.
Pressure Energy
Calculate the potential of pressure energy in a incompressible fluid.
Salt Hydrates - Melting points and Latent Melting Energy
Melting points and latent energy of salt hydrates.
Sluice Gate - Volume Flow Measurements
Sluice gates can be used to control and measure volume flow rates in open channels and rivers, mainly in connection to hydro power plants.
Static Pressure vs. Head
Work done by Force
Work done by a force acting on an object.
