Product | SG | Stypical Solids Concentration | |
% weight | % volume | ||
Coal | 1.40 | 45 - 55 | 37 - 47 |
Copper concentrate | 4.30 | 60 - 65 | 26 - 30 |
Gilsonite (asphalt, bitumen) | 1.05 | 40 - 45 | 39 - 44 |
Iron ore | 4.90 | ||
Iron sands | 1.90 | ||
Limestone | 2.70 | 60 - 65 | 36 - 41 |
Magnetite | 4.90 | 60 - 65 | 23 - 27 |
Sand | 2.65 | 43 | 23 - 30 |
Specific gravity of water based slurries vs. specific gravity of the solid and consentration of the solid in the slurry:
Densities of common products - Imperial and SI-units.
Calculate fluid velocity and volume flow in pipes and tubes.
Flow velocities in slurry transport systems to avoid settling of solids.
Volume of natural stockpiles - cubic feet, yard, metre and decimetre.
