Centrifugal Pumps - Capacity Modulation
It is often necessary to adapt pump capacities to temporary or permanent changes in the process demand.
The capacity of a centrifugal pump can be regulated either at
- constant speed, or
- varying speed
Capacity Regulating by Varying Speed
Speed modulation is energy efficient since the energy to the pump is reduced with by decreasing the impeller speed.
The speed of the pump can be varied with
- hydraulic/hydrostatic drives - hydraulic coupling between input and output shaft - speed ratio 5 to 1 is controlled by adjusting the volume of oil in the coupling
- mechanical drives - belt and sheave drive
- eddy current drive/clutch - magnetic coupling transfer load torque between input and output shaft
- variable speed drives - inverters - AC drives - adjustable frequency drives - operates by varying the frequency and voltage to the electric motor
The change in power consumption, head and volume rate can be estimated with the help of the affinity laws.
Modulating Capacity at Constant Speed
Capacity can be regulated at constant speed by
- throttling
- bypassing flow
- changing impeller diameter
- modifying the impeller
Throttling
Throttling can be carried out by opening and closing a discharge valve.
Throttling is energy inefficient since the energy to the pump is not reduced. Energy is wasted by increasing the dynamic loss.
Bypassing Flow
The discharge capacity can be regulated by leading a part of the discharge flow back to the suction side of the pump. Bypassing the flow is energy inefficient since the energy to the pump is not reduced.
Changing the Impeller Diameter
Reducing the impellers diameter is a permanent change and the method can be used where the change in process demand is not temporary. The method may be energy efficient if the motor is changed and the energy consumption reduced.
Modifying the Impeller
The flow rate and the head can be modulated by changing the pitch of the blades. Complicated and seldom used.
Pump Regulation and Power Consumption
Comparing power consumption:
• Pumps
• Water Systems
Affinity Laws for Pumps: Principles, Formulas & Calculator
Turbo machines affinity laws can be used to calculate volume capacity, head or power consumption in centrifugal pumps when changing speed or wheel diameters.
BEP - the Best Efficiency Point of a Pump
BEP is where the pump is most efficient.
Centrifugal Pumps
Pump - Temperature Rise vs. Volume Flow
Calculate temperature rise vs. volume flow in pumps.
Pump Head and Pressure: Conversion, Calculations, and Charts
Converting head (ft or m) to pressure (psi or bar, kg/cm2) and vice versa.
Pumps - Specific Speed
Characterizing of impeller types in pumps in a unique and coherent manner.
