BEP - the Best Efficiency Point of a Pump
A practical pump will never be able to convert all its kinetic energy to pressure energy. Parts of the energy will always be internal or external lost.
Internal Losses
- hydraulic loss - due to disk friction in the impeller, rapid change in flow directions and velocity changes throughout the pump
- volumetric loss - due to internal re-circulation caused by wear in rings and bushes
External Losses
- mechanical loss - due to friction in seals and bearings
BEP - Best Efficiency Point
The maximum efficiency for a pump is normally in its "design point" - also called
- BEP - or the "Best Efficiency Point"
For pumps operating in all other positions - the efficiency will be less than in BEP.
• Pumps
Centrifugal Pumps
Centrifugal Pumps - Capacity Modulation
Modulating pumps to adapt capacities to variable process demands.
Centrifugal Pumps - Influence of Viscosity
Hydrodynamic losses through pumps depends on fluid viscosities.
Comparing Hydraulic Pumps
Comparing different types of hydraulic pumps and their maximum pressures and flow.
Pump - Temperature Rise vs. Volume Flow
Calculate temperature rise vs. volume flow in pumps.
Pumps - Specific Speed
Characterizing of impeller types in pumps in a unique and coherent manner.
System Curve and Pump Performance Curve
Utilize the system curve and the pump performance curve to select the proper pump for a particular application.
