Orifices - Natural Gas Capacity
Natural gas orifice capacities:
Orifices - Natural Gas Capacities
Drill Size
(Wire Gauge)
Capacity
(ft3/hr)(Btu/hr)(kW)
70 1.34 1340 0.39
60 2. 75 2750 0. 81
50 8.35 8350 2.5
40 16.55 16550 4.9
30 28.50 28500 8.4
20 44.75 44750 13.1
  • Pressure 3.5" water column
  • Energy content 1000 Btu/ft3 natural gas
Gases and Compressed Air
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Gases - Densities
LNG - Liquefied Natural Gas
LNG or Liquefied Natural Gas.
Natural Gas - Equipment Consumption
Natural gas consumption for equipment like boiling pans, ovens, cookers, kettles and more.
Natural Gas - Pipe Sizing Calculator
Calculate capacities and dimensions of natural gas pipe lines.
Natural Gas Laboratory Consumption vs. no. of Outlets
Natural gas consumption in laboratory outlets.
Natural Gas Pipes - Low Pressure Capacities vs. Size
Sizing low pressure natural gas pipe lines - Imperial units.
Natural Gas Piping - Sizing of Low Pressure Pipes vs. Capacity
Sizing low pressure natural gas pipe lines - Metric units.
Natural Gas Piping - Sizing vs. Capacity
Sizing natural gas pipes - pressures above 5 psi (35 kPa).
Orifice Air Discharge vs. Pressure
Nozzles discharging air volume.
Steam Flow - Orifices
Steam flow through orifices - for steam pressures ranging 2 - 300 psi
Steam Leaks through Orifices
Steam leaks through orifices for pressures ranging 250 - 600 psi
