Natural Gas Piping - Sizing of Low Pressure Pipes vs. Capacity
The tables and diagrams below can be used to size natural gas pipes.
Steel Pipe - Schedule 40
Natural Gas - Sizing of Low Pressure Steel Pipes - Schedule 40
Pipe Size
(in)
Capacity of Pipe (kW)
Pipe Length (m)
36122450
1/2 41 28 19 13 9
3/4 86 59 40 28 19
1 161 110 76 52 35
1 1/4 331 228 155 108 72
1 1/2 495 340 235 161 108
2 956 655 450 310 210
2 1/2 1520 1045 720 495 330
3 2690 1850 1270 875 590
4 5490 3775 2595 1780 1200
5 9935 6830 4695 3225 2170
6 16090 11055 7600 5220 3510
8 33050 22715 15615 10730 7210
  • pressure less than 10 kPa
  • fittings factor 1.5 - equivalent pipe length = pipe length + 50%
  • pressure drop 125 Pa
  • energy content in natural gas 37 MJ/m3
  • steel pipes schedule 40
Copper Tubing - type K
Natural Gas - Sizing of Low Pressure Copper Tubing - type K
Nominal Pipe Size (O.D)
(in)
Pipe Length (m)
361224
1/4 (3/8) 6 4 3 2
3/8 (1/2) 13 9 6 4
1/2 (5/8) 26 18 12 8
5/8 (3/4) 46 31 21 15
3/4 (7/8) 65 45 31 21
1 (1 1/8) 140 96 66 45
1 1/4 (1 3/8) 250 170 119 82
  • copper tubing type K
Copper Tubing - type L
Natural Gas - Sizing of Low Pressure Copper Tubing - type L
(in)
Pipe Length (m)
361224
1/4 (3/8) 7 5 3 2
3/8 (1/2) 15 10 7 5
1/2 (5/8) 29 20 13 9
5/8 (3/4) 49 33 23 16
3/4 (7/8) 75 51 35 24
1 (1 1/8) 150 104 71 49
1 1/4 (1 3/8) 260 180 124 85
  • copper tubing type L
Fluid Flow and Pressure Loss
Gases and Compressed Air
Gas Pipes - Approved Materials
Materials approved for gas pipes.
House Gas Pipes - Capacities vs. Dimensions
Carrying capacity of house gas pipes - in imperial and metric units.
LNG - Liquefied Natural Gas
LNG or Liquefied Natural Gas.
Natural Gas - Equipment Consumption
Natural gas consumption for equipment like boiling pans, ovens, cookers, kettles and more.
Natural Gas - Meter Capacities
Types of natural gas meters and their capacities.
Natural Gas - Pipe Sizing Calculator
Calculate capacities and dimensions of natural gas pipe lines.
Natural Gas Apartment Consumption vs. no. of Apartments
Multiple apartments and natural gas demand.
Natural Gas Laboratory Consumption vs. no. of Outlets
Natural gas consumption in laboratory outlets.
Natural Gas Pipes - Low Pressure Capacities vs. Size
Sizing low pressure natural gas pipe lines - Imperial units.
Natural Gas Pipes - Minimum Cover
Burial dept and minimum cover of underground natural gas pipes.
Natural Gas Piping - Sizing vs. Capacity
Sizing natural gas pipes - pressures above 5 psi (35 kPa).
Orifices - Natural Gas Capacity
Capacity of natural gas orifices.
