LNG - Liquefied Natural Gas
LNG is Natural Gas cooled down to condensate at -161 oC (-258 oF).
Natural gas consists primarily of methane. Impurities and heavy hydrocarbons from the gaseous fossil fuel are removed before the cooling process.
The density of LNG is roughly in the range 410 to 500 kg/m3. The volume of the liquid is approximately 1/600 of the gaseous volume at atmospheric conditions.
• Combustion
• Gases and Compressed Air
Gases - Gross and Net Heat Values
Gross heat and net heat values for gases like hydrogen, methane and more.
LPG - Liquefied Petroleum Gas
LPG or Liquefied Petroleum Gas.
Natural Gas - Equipment Consumption
Natural gas consumption for equipment like boiling pans, ovens, cookers, kettles and more.
Natural Gas Apartment Consumption vs. no. of Apartments
Multiple apartments and natural gas demand.
Natural Gas Laboratory Consumption vs. no. of Outlets
Natural gas consumption in laboratory outlets.
Natural Gas Piping - Sizing of Low Pressure Pipes vs. Capacity
Sizing low pressure natural gas pipe lines - Metric units.
Natural Gas Piping - Sizing vs. Capacity
Sizing natural gas pipes - pressures above 5 psi (35 kPa).
Orifices - Natural Gas Capacity
Capacity of natural gas orifices.
