Natural Gas Pipes - Minimum Cover
  • underground natural gas steel pipe in the outside should have at least 12 inches (0.3 m) of cover
  • plastic pipes with natural gas should have at least 18 inches (0.45 m) of cover
Gases and Compressed Air
House Gas Pipes - Capacities vs. Dimensions
Carrying capacity of house gas pipes - in imperial and metric units.
Natural Gas - Equipment Consumption
Natural gas consumption for equipment like boiling pans, ovens, cookers, kettles and more.
Natural Gas Pipes - Low Pressure Capacities vs. Size
Sizing low pressure natural gas pipe lines - Imperial units.
Natural Gas Piping - Sizing of Low Pressure Pipes vs. Capacity
Sizing low pressure natural gas pipe lines - Metric units.
Underground Pipes - Earth Pressure
Pressure acting on underground pipes due to weight of soil and transport.
