Orifice Air Discharge vs. Pressure
The diagram below indicates the air leakage or air volume passing through orifices ranging size 1/64 - 1/4 inches. For well rounded nozzles multiply the vlues in the diagram with 0.97. For sharp edged nozzles multiply the values with 0.65.
- 1 psig = 6.9 kPa = 0.069 bar
- 1 inch = 25.4 mm
- 1 scfm = 0.472 nl/s
• Gases and Compressed Air
Orifice, Nozzle and Venturi Flow Rate Meters
Orifices - Natural Gas Capacity
Capacity of natural gas orifices.
Steam Flow - Orifices
Steam flow through orifices - for steam pressures ranging 2 - 300 psi
Steam Leaks through Orifices
Steam leaks through orifices for pressures ranging 250 - 600 psi
