Cast Iron Flanges - ASME/ANSI Class 25
ASME/ANSI B16.1 - 1998 - Cast Iron Pipe Flanges and Flanged Fittings - Class 25 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Cast Iron Flanges - ASME/ANSI 25 lb
Pipe Size
(inches)
Outside Diameter
(inches)
Number of Bolt HolesBolt Hole Diameter
(inches)
Bolt Circle
(inches)
4 9 8 3/4 7-1/2
5 10 8 3/4 8-1/2
6 11 8 3/4 9-1/2
8 13-1/2 8 3/4 11-3/4
10 16 12 3/4 14-1/4
12 19 12 3/4 17
14 21 12 7/8 18-3/4
16 23-1/2 16 7/8 21-1/4
18 25 16 7/8 22-3/4
20 27-1/2 20 7/8 25
24 32 20 7/8 29-1/2
30 38-3/4 28 1 36
36 46 32 1 42-3/4
42 53 36 1-1/8 49-1/2
48 59-1/2 44 1-1/8 56
54 66-1/4 44 1-1/8 62-3/4
60 73 52 1-1/4 69-1/4
72 86-1/2 60 1-1/4 82-1/2
84 99-3/4 64 1-3/8 95-1/2
96 113-1/4 68 1-3/8 108-1/2
  • 1 inch = 25.4 mm
Piping Systems
ASME/ANSI B16 Standards for Pipes and Fittings
The ASME B16 standards covers pipes and fittings in cast iron , cast bronze, wrought copper and steel.
Cast Iron
The four basic types of cast iron - white iron, gray iron, ductile iron and malleable iron.
Cast Iron Flanged Pipe Fittings - Working Pressures vs. Temperature
Maximum working pressures for cast iron flanged pipe fittings according ANSI B16.1.
Cast Iron Flanges - ASME/ANSI Class 125
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 125 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Cast Iron Flanges - ASME/ANSI Class 250
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 250 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Cast Iron Flanges - Stud Reference Chart
The number, diameter and length of studs for cast iron flanges class 125 and 250.
