1) For liquid services - flanges only. Materials of construction ASTM A 126 Class B
The ASME B16 standards covers pipes and fittings in cast iron , cast bronze, wrought copper and steel.
The four basic types of cast iron - white iron, gray iron, ductile iron and malleable iron.
Maximum working pressures for cast iron flanged pipe fittings according ANSI B16.1.
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 125 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
ASME/ANSI B16.1 - 1998 - Cast Iron Pipe Flanges and Flanged Fittings - Class 25 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 250 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
The number, diameter and length of studs for cast iron flanges class 125 and 250.
Maximum working pressures for cast iron threaded pipe fittings according ANSI B16.4.
