- T -
Thermal properties of air at different temperatures - density, viscosity, critical temperature and pressure, triple point, enthalpi and entropi, thermal conductivity and diffusivity and more.
Ideal gas properties of air at low pressure - SI units.
A dimensionless number approximating the ratio of momentum diffusivity to thermal diffusivity.
