Using air to heat buildings - temperature rise diagram
Thermal resistance in common building elements as walls, floors and roofs above and below the ground
Calculating expansion volume in open, closed and diaphragm expansion tanks
Chimneys and fireplace sizing for fireplaces and stoves burning wood or coal as fuel
Differential pressure due to difference in density between hot and cold water is the circulating force in a self circulating heating system
Classification of coal based on volatile matter and cooking power of clean material
Classification of gas oil based on BS 2869 - Specification for fuel oils for agricultural, domestic and industrial engines and boilers
Classification of boilers according ASME Boiler and Pressure Vessel Code
Hot-water heating systems can be classified by temperature and pressure
Low temperature closed expansion tank sizing
Calculate the vertical air flow and air velocity generated by a heat source
A hot or cold vertical surface will generate a vertical airflow - calculate air velocity and volume of the air flow
Low temperature diaphragm expansion tank sizing - tank volume and acceptance volume
Calculating pressure loss in piping systems with the Equivalent Pipe Length Method
Minor pressure loss for fittings in piping heating systems
Calculating flow rates in heating systems
Seasonal effects on flow temperatures in hot-water heating systems
Specific heat capacity of some common food and foodstuff as apples, bass, beef, pork and much more
Hot water heat carrying capacity of copper tube type L
Heat emission from steam or water heating pipes submerged in oil or fat - assisted (forced) and natural circulation
Heat transmission from steam or water heating pipes submerged in water - assisted (forced) and natural circulation
Calculating heat emission from new and existing column and panel radiators
Heat emission from radiators and heating panels depends on inlet, outlet and surrounding temperatures
Overall heat transfer loss from buildings - transmission, ventilation and infiltration
Heat loss from insulated and uninsulated, sheltered and exposed heated oil tanks
Heat loss from insulated and non insulated sheltered and exposed tanks and pipes
Due to evaporation - heat loss from open water tank as a swimming pools, may be considerable
Heat loss through common building elements due to transmission, R-values and U-values - imperial and SI units
Rating performance and efficiency of heat pumps
Convective air flows from some common heat sources - people, computers, radiators and more
Tutorial to heat, work and energy - essentials as specific heat and specific heat capacity
Steel pipes and tubes - pressure loss diagram hot water heating systems
A hot water heating system design procedure - heat loss, boiler rating, heater units and more
An introduction to Gravity Heating Systems and Forced Heating Systems
Hot water circulation through boilers - Imperial and SI-units
Recommended indoor temperature and humidity for some common industrial products and production processes
Recommended indoor temperatures summer and winter
Installed light power in some common types of buildings and rooms
Adapting the hot water heating temperature to outdoor temperature allows modulating valves to operate in their design range
Outdoor design temperature and relative humidity in US states and cities - summer and winter
The relationship between outdoor and indoor temperature rise - and the effect on the relative humidity
Average overall heat transmission coefficients for some common fluids and surface combinations as Water to Air, Water to Water, Air to Air, Steam to Water and more
Equivalent length of fittings like bends, returns, tees and valves in hot water heating systems - equivalent length in feet and meter
An survey of international safety valve standards. The most common used standards in Germany, UK, USA, France, Japan, Australia and Europe
Maximum safety valves free air relief capacity
Boilers 275 to 1500 kW and Safety Valves
Calculating outdoor swimming pool heaters
Sizing water antifreeze snow melting systems
Static pressures in HVAC system avoids the tops of the systems drying out
Cubical expansion when changing temperature - online calculator
The most common units of heat are BTU - British Thermal Unit, Calorie and Joule
Firewood and combustion heat values - Pine, Elm, Hickory and many more species
9 11 11
