Convective Air Flow - Single Heat Source
Calculate the vertical air flow and air velocity generated by a single heat source.
A heat source, like an engine, stove, melting pot or a person, will generate a convective vertical air flow as indicated in the figure below.
Convective heat flow from a single source like engine, heater or person
Air Velocity
The air velocity in the center of the air flow at a distance above the floor can be calculated as
vc = c1 (P / l)1/3                                              (1)
vc = air velocity in center of the air flow (m/s)
c1 = constant characterizing the actual application, typical values ranging 1 to 2
P = heat power from the source (kW)
l = distance above the floor and the heat source (m)
Air Flow Volume
The air flow volume in a distance above the the floor can be calculated as
Q = c2 P1/3 l5/3                                       (2)
Q = air flow volume (m3/s)
c2 = constant characterizing the actual application, values ranging 0.05 to 0.15 (typical 0.06)
Example - Convective Air Flow above an Engine
The heat loss from the surface of an engine is 10 kW. If c1 = 1.5, the air velocity 3 meters above the engine can be estimated to
vc = 1.5 ((10 kW) / (3 m))1/3
    = 2.2 m/s
With c2 = 0.06 the volume flow can be estimated to
Q = 0.06 (10 kW)1/3 (3 m)5/3
   = 0.8 m3/s
