It is common to use the Block Flow Diagram - BFD - as a schematic illustration of the major process
Before products are sold within the European - EU - market, they have to be "CE-marked"
The National Fire Protection Association (NFPA) hazard system for chemical materials
An online control valve - Cv - calculator for gases
Process control valves - flow characteristics, sizing Cv and Kv values for gas, liquid and steam valves - online calculators ..
Engineering documentation of process control systems, Block Flow Diagrams (BFD), Process Flow Diagrams (PFD) and Piping and Instrumentation Diagrams (P&ID)
Critical temperatures and concentration parameters for some common substances as coal, zinc, uranium and more
The flow coefficient - Cv - is important for proper design of control valves
Comparing flow coefficient Cv with flow factor Kv
An introduction to turndown ratio for flow measurement devices as orifices, venturi meter etc.
Orifice, Venturi, Flow Nozzles, Pitot Tubes, Target, Variable Area, Positive Displacement, Turbine, Vortex, Electromagnetic, Ultrasonic Doppler, Ultrasonic Time-of-travel, Mass Coriolis, Mass Thermal, Weir V-notch, Flume Parshall and Sluice Gate flow meters . .
European hazardous areas classifications in zones, protection types, temperature codes and codes
North American hazardous locations classification in classes, divisions and groups
IP - Ingress Protection rating is used to specify the environmental protection - electrical enclosure - of electrical equipment
ISA instrumentation codes and combinations
The ISA standards and symbols are important for the P&IDs and documents describing the process control system
Measuring relative air humidity with dry and wet bulb temperatures
A Piping and Instrumentation Diagram - P&ID, is a schematic illustration of functional relationship of piping, instrumentation and system equipment components
The Process Flow Diagram - PFD, a schematic illustration of the system
Introduction to pressure - relationship psi and Pa - online pressure units converter
Common terms in the process control terminology
Basic process controllers with proportional, integrating and derivative functions
Hazardous areas classifications, types of protection, rating systems, critical temperatures and more ..
Select and size the control valve that most closely matches the process requirements
Selecting and sizing butterfly valves for water applications
Design of steam control valves and their Kv values
Measurement of temperature; probes, sensors and transmitters
Comparing advantages and disadvantages of thermocouples, RTDs and thermistors temperature sensors
Thermocouples - types, principles and temperature ranges
An introduction to different types of fluid flowmeters - Orifices, Venturies, Nozzles, Rotameters, Pitot Tubes, Calorimetrics, Turbine, Vortex, Electromagnetic, Doppler, Ultrasonic, Thermal, Coriolis
In sewage piping and pumping systems the fluid flow rate must be kept within certain limits to avoid operating problems
Design of water process control valves and their Kv values
9 11 11
