The Engineering ToolBox Web Google
Basics
Basic Information as SI-system, Unit converters, Physical constants...
Acceleration of Gravity and Newtons Second Law
Acceleration of gravity and Newtons Second Law - SI and Imperial units.
Acceleration Units Converter
Convert between common units of acceleration
Air Properties
Temperature, density, specific heat, thermal conductivity, expansion coefficient, kinematic viscosity and Prandtl's number for temperatures ranging -150 - 400 oC
Angle Converter
Online angle units converter
British Imperial System
A principal system of units
Circles - Circumferences and Areas
Area and circumferences of circles with diameters in inches
Conversion Chart - inches to mm
Convert fractional and/or decimal inches to metric mm or vice versa
Decimal System Prefixes
Prefix Names of Multiples and Submultiples of Units
Density, Specific Weight and Specific Gravity
An introduction and definition of density, specific weight and specific gravity - formulas with examples
Empirical Equations
Empirical relationships or formulas
Equilibrium
Mechanical, thermal, electrostatic, phase and chemical equilibrium
Exponents
Fractional and integer exponents laws
Flow Units Converter
Convert between volume flow units - gpm, liter/sec, cfm, m3/h - online flow unit converter
Fraction-Decimal Equivalents
Inches - fractional decimal equivalents
Inches and Decimal Equivalents
Decimal equivalents of eights, sixteenths, thirty-seconds and sixty-fourths of an inch
Length Units Converter
Convert between common length units like meters, feet, inches, nautical miles and many more
Logarithms
Rules of logarithms - log 10 and log e for numbers ranging 1 to 1000
Mass and Weight
Weight and mass - the difference
Miscellaneous Measuring Units
Some common measuring units - gross, dozen, quire, sheets ..
Mixtures, Solutions and Suspensions
The difference between mixtures, solutions and suspensions
Mole
The mol is the SI base unit that measures an amount of substance
Moment of Inertia
Moment of Inertia (Mass Moment of Inertia) depends on the mass of the object, its shape and its relative point of rotation
Natural Trigonometric Functions
Sine, Cosine and Tangent - Natural Trigonometric Functions
Online Fuel Equivalents Calculator
Online calculator to compute the fuels equivalents - oil and gas
Online Units Conversion Calculator
Convert Energy, Pressure, Volume, Density, Specific Volume, Specific Heat (Entropy), Enthalpy, Thermal Conductivity, Viscosity (absolute) or Coefficient of Heat Transfer units
Ounces and Pounds converted into Grams
Converting ounces (ozs.) and pounds (lbs.) into grams (g)
pH Definition
An introduction to pH
ppm - parts per million
ppm - parts per million - is commonly used as unit of concentration
Pressure
Introduction to pressure - relationship psi and Pa - online pressure units converter
Pressure to Head Unit Converter
Converting between common units for pressure and head - lb/in2, atm, inches mercury, bars, Pa and more ..
Pressure Units Online Converter
Convert between common pressure units like Pa,  bar, atmosphere, pound square feet, psi and more
Properties and State
Concept of properties and state
Definition of British Horse Power for pumps, fans and turbines - how to convert to other common units
Radians
The radian - a unit of angle measure - angular velocity
Ratio and Proportion
Ratio and proportion between two quantities
Real Numbers Algebra
Real numbers algebra - commutative law for addition, associative law for addition and more
SI System
An introduction to the SI-system
Specific Heat Capacity Converter
Online specific heat calculator with the most common units
Temperature
A short introduction to temperature - including Celsius, Fahrenheit, Kelvin and Rankine definitions - online temperature converter
The Elements
The elements with name, symbol, atomic number and weight
Unit Converter with the most Common Units
Common converting units for Acceleration, Area, Density, Energy, Energy per unit mass, Force, Heat flow rate, Heat flux, Heat generation per unit volume and many more
USCS - United States Customary System Units
United States Customary System Units or Imperial Units
Vector Addition
Online vector calculator - add vectors with different magnitude and direction
Velocity Units Converter
Convert between common velocity and speed units - with an online converter
Volume and Surface of some Common Solids
Surface and volume of solids like rectangular prism, cylinder, pyramid, cone and sphere - online calculator
Volume Units Converter
Convert between common volume units like cubic meters, cubic feet, cubic inches and many more
Water - Pressure and Head
Pressure in pounds per square inch (psi) and head in feet of water (fth2o)
Water Content in Products
Products and water content before and after drying - common material like cork, grain, soap, peat, wood and more
Search the ToolBox
9 12 8
handheld Engineering ToolBox - optimized for mobile devices! 3D Engineering ToolBox - draw and model technical applications!
Resources, Tools and Basic Information  for Engineering and Design of Technical Applications!
