Arithmetic Mean Temperature Difference - AMTD - and Logarithmic Mean Temperature Difference - LMTD - formulas with examples - Online Mean Temperature Calculator
Thermal resistance in common building elements as walls, floors and roofs above and below the ground
Thermal conductivity - temperature and k-values
Heat transfer takes place as conduction if there is a temperature gradient in a solid or fluid
Heat loss to surrounding air from insulated copper tubes
Online heat loss calculator for pipes and tubes
Heat loss (W/m) diagrams for insulated pipes - ranging 1/2 - 6 inches - insulation thickness 10 - 80 mm - temperature differences 20 - 180 deg C
Heat loss (W/ft) diagrams for insulated pipes - ranging 1/2 - 6 inches - insulation thickness 0.5 - 4 inches - temperature difference 50 - 350 deg F
Heat loss from uninsulated copper pipes ranging 1/2 - 4 inches
Heat losses from bare surfaces - surface temperatures in deg F and deg C
Heat tracing wrapping factor when heat loss from pipe or tube is higher than cable capacity
Temperature limits of some common insulation materials
Insulation thickness of cooling systems
Thermal conductivity - Temperature and k-values
Calculate overall heat transfer coefficient - walls or heat exchangers
Insulation thickness of heating systems - hot water - low, medium and high pressure steam - systems
Radiation emissivity of some common materials - Water, Ice, Snow, Grass ..
Heat transfer due to emission of electromagnetic waves is known as thermal radiation
Heat loss from steel pipes and tubes - dimensions ranging 1/2 - 12 inches
Thermal conductivity of some common materials - aluminum, asphalt, brass, copper, steel and many more ..
9 11 11
