Pipes - Bare Surface Heat Loss
Heat loss vs. surface temperature.
The diagrams below indicates heat loss from uninsulated pipes with bare surfaces at still-air conditions and air temperature 70 oF (21 oC). The emissivity coefficient of the surface is 0.95.
Bare pipe surface - heat loss
  • Heat Loss and Insulation
  • Insulation
  • Insulation and Heat Loss from Steam and Condesate Pipe Lines
    Heat loss from uninsulated and insulated steam and condensate pipes and tanks. Calculate insulation thicknesses.
  • The Engineering ToolBox (2008). Pipes - Bare Surface Heat Loss . [online] Available at: https://www.engineeringtoolbox.com/heat-loss-bare-surface-d_1153.html [Accessed Day Month Year].
