Pipes - Bare Surface Heat Loss
The diagrams below indicates heat loss from uninsulated pipes with bare surfaces at still-air conditions and air temperature 70 oF (21 oC). The emissivity coefficient of the surface is 0.95.
• Heat Loss and Insulation
• Insulation
• Insulation and Heat Loss from Steam and Condesate Pipe Lines
Heat loss from uninsulated and insulated steam and condensate pipes and tanks. Calculate insulation thicknesses.
Copper Tubes - Heat Losses
Heat loss from uninsulated copper tubes vs. temperature differences between tube and air.
Oil Filled Tanks - Heat Loss
Heat loss from insulated and uninsulated, sheltered and exposed heated oil tanks.
Pipes and Cylinders - Conductive Heat Losses
Conductive heat losses through cylinder or pipe walls.
Pipes Submerged in Oil or Fat - Heat Emission
Heat emission from steam or water heating pipes submerged in oil or fat - forced and natural circulation.
Radiation - Surfaces Emissivity Coefficients
Radiation emissivity of common materials like water, ice, snow, grass and more.
Radiation Heat Transfer
Steam Pipes - Heat Losses
The amount of condensate generated in a steam pipe depends on the heat loss from the pipe to the surroundings.
Steam Pipes - Heat Losses (W/m)
Heat losses from un-insulated steam pipes.
Steam Tracing Pipe Lines
Steam tracing of pipe lines can be done to maintain appropriate product temperatures.
Surface Emissivity Coefficients
