Material Properties
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Acetylene - Thermophysical Properties
Chemical, Physical and Thermal Properties of Acetylene.
Acid and Base pH Indicators
pH range vs. color change for acid and base indicators - together with pKa and structures of the indicators.
Acids - pH Values
pH values of acids like sulfuric, acetic and more..
Density and specific volume of air varies with elevation above sea level.
Air - Density vs. Pressure and Temperatures
Air - Dynamic and Kinematic Viscosity
Air - Prandtl Number
Air - Specific Heat Ratio
Specific Heat Ratio of air at temperatures ranging -40 - 1000 degC (-40 - 1500 degF) at standard atmospheric pressure - Imperial and SI Units.
Air - Specific Heat vs. Temperature at Constant Pressure
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Thermal properties of air at different temperatures - density, viscosity, critical temperature and pressure, triple point, enthalpi and entropi, thermal conductivity and diffusivity and more.
Air Properties - Imperial Units
Thermodynamic properties of air at low pressures - imperial units.
Air Properties - SI Units
Ideal gas properties of air at low pressure - SI units.
AISI 310 Stainless Steel - Properties
Thermal diffusivity, specific heat capacity, density and thermal conductivity of stainless steel AISI 310 vs. temperature.
AISI/SAE Steel and Alloys - Designation System
The AISI/SAE carbon steel and alloys naming conventions.
Alloy Steels
Alloy steels have properties due to elements other than carbon.
Properties of alternative fuels like biodiesel, E85, CNG and more.
Aluminum - Melting Points of Binary Eutectic Alloys
Al - Aluminum - binary eutectic alloys and their melting points.
Aluminum - Thermophysical Properties
Density, specific heat and thermal conductivity related to temperature.
Aluminum Alloys - Mechanical Properties
Mechanical properties of some common aluminum alloys.
Mechanical properties of aluminum alloys - tensile strength, yield strength and more.
Amines, Diamines and Cyclic Organic Nitrogen Compounds - pKa Values
Values for the negative logarithm of the acid dissociation constant, pKa, of the conjugated acid of amines, diamines and cyclic organic nitrogen compounds, shown together with the molecular structure of the acids.
Antifreeze - Ethylene Glycol Volume vs. Temperature Rating
Freeze protecting of cooling systems - temperature rating vs. required amount of antifreeze.
Antifreeze - Ethylene Glycol vs. Propylene Glycol
Comparing ethylene glycol and propylene glycol antifreeze properties.
API Gravity
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Aqueous Salt Solutions - Acid and Base Properties
Salts contains ions that may affect the pH in aqueous solutions in both acidic and basic directions.
Argon - Thermophysical Properties
Chemical, Physical and Thermal Properties of Argon.
Arsenic - Melting Points of Binary Eutectic Alloys
As - Arsenic - binary eutectic alloys and their melting points.
Bases - pH Values
pH values for bases like sodium hydroxide, ammonia and more.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Benzene Gas - Specific Heat vs. Temperature
Specific heat of Benzene Gas - C6H6 - at temperatures ranging 250 - 900 K.
Benzene Liquid - Thermal Properties
Properties like density, specific heat, thermal conductivity, dynamic viscosity and Prandtl number.
Beryllium - Specific Heat vs. Temperatures
Specific heat of beryllium related to temperature.
Brick Densities
Densities of common types of bricks.
Brinell Hardness Number - BHN
The Brinell hardness test of metals and alloys.
Brix Scale
The content of sucrose - Brix scale vs. Specific Gravity and Plato - used in the sugar, fruit juice and wine making industry.
Bulk Modulus and Fluid Elasticities
Introduction to - and definition of - Bulk Modulus Elasticity commonly used to characterize the compressibility of fluids.
Butane - Thermophysical Properties
Chemical, physical and thermal properties of n-Butane.
Calcium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Calcium Chloride Water coolants.
Carbon and Low-Alloy Steel Classifications
Steel is considered to be carbon steel when no minimum content is specified or required for chromium, cobalt, columbium (niobium), molybdenum, nickel, titanium, tungsten, vanadium or zirconium.
Carbon Dioxide - CO2 - Liquid - Properties, Imperial Units
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Carbon Dioxide - Dynamic and Kinematic Viscosity vs. Temperature and Pressure
Online calculator, figures and table showing dynamic and kinematic viscosity of carbon dioxide, CO2, at varying temperature and pressure - Imperial and SI Units.
Carbon Dioxide - Liquid Properties
Carbon Dioxide - Specific Heat of Gas vs. Temperature
Specific heat of Carbon Dioxide gas - CO2 - temperatures ranging 175 - 6000 K.
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Carbon Dioxide - Thermophysical Properties
Carbon Monoxide - CO - Thermophysical Properties
Chemical, Physical and Thermal Properties of Carbon Monoxide - CO.
Carbon Monoxide - Density and Specific Weight vs. Temperature and Pressure
Online calculator, figures and tables showing density and specific weight of carbon monoxide, CO, at varying temperature and pressure - Imperial and SI Units.
Carbon Monoxide Gas - CO - Specific Heat vs. Temperature
Carbon Monoxide Gas - CO - specific heat of at temperatures ranging 175 - 6000 K.
Ceramic Materials - Properties
Physical properties of ceramics.
Chromium - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of chromium related to temperature.
Combustion Heat
Combustion of Fuels - Carbon Dioxide Emission
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy.
Composition of Steels
Typical composition of AISI steels.
Compressed Water - Properties vs. Temperature
Specific volume, enthalpy and entropy of compressed water.
Compression and Tension Strength of some common Materials
Common materials and average ultimate compression and tension strength.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Properties
Properties of normal strength Portland cement concrete.
Copper - Density, Specific Heat and Thermal Conductivity vs. Temperature
Density, specific heat and thermal conductivity of copper vs. temperature
Copper Alloys - Typical Applications
Typical use of copper alloys in architecture, automotive, electrical, building wire, energy, tube, pipe fittings, fuel gas, industrial and marine applications.
Copper Binary Eutectic Alloys - Melting Points
Cu - Copper - binary eutectic alloys and their melting points.
Copper, Zinc and Tin Alloys
Strength of Copper, Zinc and Tin alloys.
CPVC - Chemical Resistance
Chemical resistance of CPVC - Chlorinated Poly (Vinyl Chloride) - to common chemicals and products.
Crude Oil Metal (Ni, V) Content vs. Gravity
Content of nickel and vanadium in more than 120 crudes as function of specific gravity@15°C/60°F.
Crude Oil Properties - Standard test methods (ASTM and others)
An overview of common test methods and typical ranges of variation of petroleum quality parameters. What, why and how do the different test?
Crude Oil Viscosity vs. Gravity
Viscosity at 20°C/68°F and 50°C/122°F for more than 120 crudes is shown as function of specific gravity@15°C/60°F.
Cryogenic Fluids and Liquefied Gas Properties
Cryogenic properties as density, boiling points and heat of evaporation for fluids like hydrogen, methane, oxygen, nitrogen, fluorine and helium.
Densities of common Products
Densities of common products - Imperial and SI-units.
Density Converter
An introduction to density, specific weight and specific gravity.
Dichlorodifluoromethane - Properties
Properties of saturated liquid Dichlorodifluoromethane R-12 - CCl2F2 - density, specific heat capacity, kinematic viscosity, thermal conductivity and Prandtl number.
Dichlorodifluoromethane - Properties, Imperial Units
Properties of saturated liquid Dichlorodifluoromethane - CCl2F2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Dimethyl Propylmethane Gas - Specific Heat vs. Temperature
Specific heat of Dimethyl Propylmethane Gas - C6H18 - at temperatures ranging 250 - 800 K.
Dirt and Mud - Densities
Densities - pound per cubic foot and kilograms per cubic metre - of dirt and mud.
Ditch Filling Materials - Densities
Weight or density of ditch filling materials.
Dry Air - Thermodynamic and Physical Properties
Thermodynamic properties of dry air - specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Drying Temperature and Time for Products
Drying temperature and time for products like food, coffee, fruits, lumber and more.
Dust Explosions - Substances, Critical Temperatures and Concentrations
Critical temperatures and concentration parameters for substances like coal, zinc, uranium and more.
Elastomers
Natural and syntetic rubbers guide.
Elements - Boiling Points
Elements and their boiling points.
Elements - Melting Points
Melting points of elements.
Engine Oil - Density and Specific Heat vs. Temperatures
Specific heat and density of new engine oil related to temperature.
Engineering Materials - Properties
Some typical properties of engineering materials like steel, plastics, ceramics and composites.
Epoxy - Chemical Resistance
Chemical resistance of Epoxy to common products like Acetic acid, Alcohol, Diesel oil and more.
Ethane - Dynamic and Kinematic Viscosity
Online calculator, figures and tables showing dynamic and kinematic viscosity of ethane, C2H6, at varying temperature and pressure - Imperial and SI Units
Ethane Gas - Specific Heat vs. Temperature
Specific heat of Ethane Gas - C2H6 - for temperatures ranging 250 - 900 K.
Ethane Liquid - Thermal Properties
Density, specific heat and more of liquid ethane.
Ethanol - Thermophysical properties
Chemical, physical and thermal properties of ethanol (also called alcohol or ethyl alcohol). Phase diagram included.
Ethanol Freeze Protected Water Solutions
Freezing temperature and flash points for ethanol based water solutions or brines.
Ethanol Water Mixtures - Densities vs. Temperature
Density of Ethyl Alcohol aqueous solutions.
Ethylene Gas - Specific Heat vs. Temperature
Specific heat of Ethylene Gas - C2H4 - temperatures ranging 175 - 900 K.
Ethylene Glycol Heat-Transfer Fluid Properties
Fibre-reinforced Polymer Composites
Mechanical properties of fibers used to reinforce polymer composites.
Float Glass - Weight vs. Thickness
Weight of float glass.
Food and Foodstuff - pH Values
pH in common food products - like apples, butter, wines and more.
Food and Foodstuff - Specific Heat
Specific heat of common food and foodstuff like apples, bass, beef, pork and many more.
Food Products - Bulk Densities
Bulk densities of some common food products like grain, corn, barley, sugar and more.
Food Products - Viscosities
Absolute (dynamic) viscosity for common food products.
Foods - Thermal Conductivities
Thermal conductivity of selected foodstuff like apples, beef, sugar and more.
Foodstuff - Thermal Diffusivity
Thermal diffusivity of some selected food products.
Fossil vs. Alternative Fuels - Energy Content
Net (low) and gross (high) energy content in fossil and alternative fuels.
Fuels - Densities and Specific Volumes
Densities and specific volumes fuels like anthracite, butane, gasoil, diesel, coke, oil, wood and more.
Fuels - Properties Database
Online petroleum-based fuels properties database.
Gas Data
Online database with gas properties.
Gases - Densities
Gases - Dynamic Viscosities
Absolute (dynamic) viscosities of some common gases.
Gases - Molar Specific Heats
Molar specific heats for some common gases at constant volume.
Gases - Specific Gravities
Specific gravities of air, ammonia, butadiene, carbon dioxide, carbon monoxide and some other common gases.
Gases - Specific Heats and Individual Gas Constants
Gasoline - Density, Specific Heat, Viscosity and Thermal Conductivity vs. Temperature
Glycerine - Boiling and Freezing Points
Boiling and freezing points of glycerine aqueous solutions.
Gold Binary Eutectic Alloys - Melting Points
Some Au - Gold - binary eutectic alloys and their melting points.
Hardwood and Softwood Species
Species of hardwood vs. softwood.
Hazard vs. Flash Points
The flash point of a chemical indicates how easy it may ignite and burn.
Heat Capacity
Helium - Thermophysical Properties
Chemical, Physical and Thermal Properties of Helium - He.
Human Body - Specific Heat
Specific heat of the human body - compared to substances like protein and wood.
Hydrocarbon Mixtures - Average Boiling Points vs. Gravity and Molecular Weights
Formulas and examples of calculation of boiling point of hydrocarbon mixtures from gravity and molecular weight.
Hydrocarbon Mixtures - Molecular Weight vs. Gravity and Average Boiling Point
Formulas and examples of calculation of average molecular weight of hydrocarbon mixtures from gravity and average boiling point, achieved from distillation data.
Hydrocarbons - Physical Data
Hydrocarbons - Autoignition Temperatures and Flash Points
Autoignition temperatures and flash points (°C and °F) of different types of hydrocarbons with varying carbon numbers up to C12.
Hydrocarbons - Melting Point vs. Molecular Weight
Calculate melting point of hydrocarbons from molecular weight (molar mass).
Hydrocarbons - Vapor Pressures
Vapor pressure vs. temperature for propane, n-butane, n-heptane and n-pentane hydrocarbons.
Hydrogen - Specific Heat
Specific heat of Hydrogen Gas - H2 - at temperatures ranging 175 - 6000 K.
Chemical, Physical and Thermal Properties of Hydrogen - H2.
Hydrogen sulfide - Thermophysical Properties
Chemical, physical and thermal properties of hydrogen sulfide, H2S, also called hydrosulfuric acid, sewer gas and stink damp. Phase diagram included.
Ice - Properties
Properties like Youngs modulus, tensile strength, compressive strength and fracture of toughness for ice.
Ice - Safe Loads vs. Thickness
Safe loads vs. thickness for clear and solid ice.
Ice - Thermal Properties
Thermal and thermodynamic properties of ice like density, thermal conductivity and specific heat at temperatures from 0 to -100 oC.
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
Inorganic Acids and Bases - pKa Values
Values for the negative logarithm of the acid dissociation constant, pKa, of inorganic acids and bases, as well as hydrated metal ions.
Ionic Compounds in Water - Solubility Guidelines
Guidelines or solubility rules to predict whether or not a given ionic compound is soluble in water at room temperature.
Iron - Density, Specific Heats and Thermal Conductivities vs. Temperatures
Specific heat, density and thermal conductivity of iron related to temperature.
Iron Binary Eutectic Alloys - Melting Points
Fe - Iron - binary eutectic alloys and melting points.
Isopropanol (2-Propanol) based Freeze Protected Water Solutions
Freezing and flash points of isopropanol (2-Propanol) based water solutions or brines.
Lead Binary Eutectic Alloys - Melting Points
Pb - Lead (Plumbum) - binary eutectic alloys and melting points.
Liquid-Liquid Solution - Shrinkage and Estimation of Density
It is possible to estimate the density of a liquid-liquid solution from the density of the solute and the solvent. However, due to shrinkage, the estimate will be a bit too low.
Liquids - Densities
Liquids - Dielectric Constants
Dielectric constants or permittivities of some fluids or liquids.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
Liquids - Freezing and Melting Points
Common fluids and their freezing and melting points.
Liquids - Latent Heat of Evaporation
Latent heat of vaporization for fluids like alcohol, ether, nitrogen, water and more.
Liquids - Specific Gravities
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Specific gravities for common fluids like acetone, alcohol, turpentine, oil and more.
Liquids - Vapor Pressures
Vapor and saturation pressure for some common liquids.
Liquids and Fluids - Specific Heats
Lumber - Weights
Magnesium Binary Eutectic Alloys - Melting Points
Mg - Magnesium - binary eutectic alloys and melting points.
Malleability vs. Brittlenes vs. Ductility
Plastic deformation properties.
Melting and Boiling Temperatures - Evaporation and Melting Heats common Materials
Melting and boiling point temperatures, latent heat of evaporation, and melting heat of common substances like copper, gold, lead and more - SI units.
Mercury - Thermodynamic Properties
Properties of saturated liquid Mercury - Hg - density, specific heat capacity, kinematic viscosity, thermal conductivity and Prandtl number.
Metal Alloys - Melting Points
Alloys and their melting points.
Metal Alloys - Specific Heats
Specific heat of metal alloys like brass, bronze and more.
Metals - Boiling Points and Specific Heat
Boiling points and specific heat of liquid metals.
Metals - Boiling Temperatures
Metals and their boiling temperatures.
Metals - Latent Heat of Melting
Metals and their latent heat of fusion.
Metals - Machinability
The machinability of some common metals.
Metals - Specific Heats
Metals - Strength vs. Temperature
The influence of temperature on the strength of metals.
The Bulk Modulus - resistance to uniform compression - for some common metals and alloys.
Metals and Alloys - Densities
Metals in Seawater - Galvanic Series
Galvanic series of metals in seawater.
Metals, Metallic Elements and Alloys - Thermal Conductivities
Thermal conductivities of common metals, metallic elements aand alloys.
Online calculator, figures and table showing thermal conductivity of methane, CH4, at temperatures ranging from -160 to 725 °C (-260 to 1300 °F) at atmospheric and higher pressure - Imperial and SI Units.
Methane - Thermophysical Properties
Methane Gas - Specific Heat vs. Temperature
Specific heat of Methane Gas - CH4 - at temperatures ranging 200 - 1100 K.
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Methanol - Specific Heat vs. Temperature and Pressure
Online calculator, figures and tables showing isobaric and isochoric specific heat of methanol, CH3OH, at varying temperature - Imperial and SI Units.
Methanol - Thermophysical Properties
Chemical, physical and thermal properties of methanol, CH3OH (also called carbinol, wood alcohol, hydroxy methyl and methyl alcohol). Phase diagram included.
Methanol - Thermophysical Properties vs. Temperature
Thermophysical properties of methanol.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
Mineral Hardness - Mohs Scale
The Mohs qualitative ordinal scale characterizes the scratch resistance of various minerals.
Minerals - Densities
Densities of minerals.
Minerals and other Materials - Specific Gravities
Specific gravities for minerals and other materials.
Moisture Content Calculation
Calculate the moisture content in products like wood on wet and dry basis.
Molybdenum Binary Eutectic Alloys - Melting Points
Mo - Molybdenum - binary eutectic alloys and melting points.
Nickel Binary Eutectic Alloys - Melting Points
Ni - Nickel - binary eutectic alloys and melting points.
Nitrogen - Density and Specific Weight vs. Temperature and Pressure
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Nitrogen - Dynamic and Kinematic Viscosity vs. Temperature and Pressure
Online calculator, figures and tables showing dynamic and kinematic viscosity of nitrogen, N2, at varying temperature and pressure - Imperial and SI Units.
Online calculator, figures and tables showing thermal conductivity of nitrogen, N2, at varying temperarure and pressure, SI and Imperial units.
Nitrogen - Thermal Diffusivity vs. Temperature and Pressure
Figures and tables showing thermal diffusivity of nitrogen at varying temperarure and pressure, SI and Imperial units.
Nitrogen Gas - Specific Heat vs. Temperature
Specific heat of Nitrogen Gas - N2 - at temperatures ranging 175 - 6000 K
Octane Liquid - Thermal Properties
Density, specific heat, thermal conductivity and more.
Oils - Melting points
Common oils from animals or plants and their melting points.
Organic Nitrogen Compounds - Physical Data
Boiling and melting points of amines, diamines, pyrroles, pyridines, piperidines and quinolines shown together with their molecular structures, as well as molweights and density.
Organic Sulfur Compounds - Physical Data
Boiling and melting points of thoils, sulfides, disulfides and thiophenes shown together with molecular structures, as well as molweights and density.
Solubility of oxygen in equilibration with air in fresh water and seawater (salt water) - pressures ranging 1 - 4 bar abs.
Specific heat of Oxygen Gas - O2 - at temperatures ranging 175 - 6000 K.
Particle Sizes
The size of dust particles, pollen, bacteria, virus and many more.
Permeability
Electromagnetism and formation of magnetic fields.
Petroleum Products - Average Boiling Points
Definition, explanation and examples of calculation of various types of average boiling point of petroleum products and other mixtures of hydrocarbons: VABP, MABP, WABP, CABP and MeABP.
Petroleum Products - Standard Test Methods (ASTM and others) and Specifications
An overview of common test methods and specifications of petroleum fuels. What, why and how do the different test?
pH in Human Biological Material
pH in human materials like blood, salvia and more.
Phenols, Alcohols and Carboxylic Acids - pKa Values
For oxygen containing organic compounds this is given: pKa (the negative logarithm of the acid dissociation constant), molecular structures, molar weights, density and melting and boiling points.
Plastics - Abbreviations
Commonly used plastic abbreviations.
Plastics - Recycling Codes and Labeling
Symbol codes and labeling used for recycling plastic products like bottles, containers and packagin.
Thermal conductivity of plastics.
Plato and Brix vs. Specific Gravity
Convert between units like Plato, Brix and SG (Specific Gravity) used to measure sucrose dissolved in water.
Polyester - Chemical Resistance
Chemical resistance of Polyester to products like Acetic acid, Diesel oil and others.
Polymers - Physical Properties
Densities, tensile strength, elongation, Youngs modulus and Brinell hardness.
Polymers - Specific Heats
Specific heat of polymers like epoxy, PET, polycarbonate and more.
Polyurethane - Chemical Resistance
Chemical resistance of Polyurethane (PUR).
Porosity
Volume not occupied by solid material.
Potassium - Thermophysical Properties vs. Temperature
Thermophysical properties of potassium.
PP Polypropylene - Chemical Resistance
Chemical resistance of Polypropylene - PP - to acids, bases, organic substances and solvents.
Propane - Specific Heat vs. Temperature and Pressure
Online calculators, figures and tables with specific heat, Cp and Cv, of gasous and liquid propane, C3H8 vs. temperature and pressure - Imperial and SI Units .
Propane - Thermal Diffusivity vs. Temperature and Pressure
Propane Butane Mixture - Evaporation Pressure
PVC Polyvinyl Chloride - Chemical Resistance
Chemical resistance of Polyvinyl Chloride PVC.
R22 Refrigerant - Properties
Properties of Refrigerant R22 Dichlorodifluoromethane - saturated liquid and saturated vapor - imperial and metric units.
Radiation - Surfaces Emissivity Coefficients
Radiation emissivity of common materials like water, ice, snow, grass and more.
Radioisotopes - Half Lives
Time for isotop radiation to be reduced with 50%.
Refractive Index common Liquids, Solids and Gases
Some common fluids and their refractive index.
Refrigerants - Environmental Properties
Physical and environmental properties of some common refrigerants.
Refrigerants - Physical Properties
Physical properties of refrigerants - molecular weight, boiling, freezing and critical points.
Rubbers and Elastomers - Chemical Resistance
Rsistance to chemicals - solvents and softeners - swelling properties.
Viscosities and densities of SAE Grade oils.
Saturated Ice and Steam - Thermodynamic Properties
Thermodynamic properties of saturated ice and steam - specific volume, enthalpy and entropy.
Saturated Salt Solutions - Controlling Air Humidity
A salt solutions can be used maintain a particular value of relative humidity.
Seawater - Properties
Seawater properties like density, saturation pressure, specific heat, electrical conductivity and absolute viscosity.
Silicone - Chemical Resistance
Chemical resistance of silicone.
Silver Binary Eutectic Alloys - Melting Points
Ag - Silver - binary eutectic alloys and melting points.
Slurry Densities
Calculate density of a slurry.
Sodium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Sodium Chloride and Water coolant.
Soft or Hard Water
Carbonates dissolved in water.
Softwood Lumber - Standard Sizes
Nominal and minimum-dressed lumber sizes.
Soil - Earth Weight and Composition
Typical weight and composition of soil.
Solids - Densities
Densities of selected solids.
Solids - Melting and Boiling Temperatures
Melting and boiling temperatures of some products.
Solids - Specific Heats
Solids and Metals - Specific Gravities
Specific gravity for common solids and metals like aluminum, asbestos, brass, calcium and many others.
Thermal conductivity coefficients for insulation materials, aluminum, asphalt, brass, copper, steel, gases and more.
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
Solubility Product Constants
The equilibrium constant, Ksp, for aqueous solutions of ionic compounds at 25°C.
Solutions, Molarity and Dilution
Definitions and examples of how to calculate wt%, molarity and how to prepare dilutions.
Specific Heat of common Substances
Stainless Steel - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of stainless steel vs. temperature
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Stainless Steels - Identification Tests
Magnetic, spark, hardness and acid identification tests for austenitic, martensitic and ferritic stainless steels.
Standard State and Enthalpy of Formation, Gibbs Free Energy of Formation, Entropy and Heat Capacity
Definition and explanation of the terms standard state and standard enthalpy of formation, with listing of values for standard enthalpy and Gibbs free energy of formation, as well as standard entropy and molar heat capacity, of 370 inorganic compounds.
Steel Tempering Colors
The tempering process of hardening steel.
Stone Masonry - Strength
Typical strength of stone masonry constructions.
Stones - Weight and Strength
Weight and strength of sandstone, granite, limestone, marble and slate.
Strong and Weak Acids and Bases
The most common strong acids and bases, and some examples of weak acids and bases, together with definition of strong and weak acids and bases.
Structural Lumber - Section Sizes
Basic size, area, moments of inertia and section modulus for timber - metric units.
Substances Triple Points
Triple points for common substances.
Sugar Solubility in Water
Solubility of sugar in water.
Sugar Water Solutions - Viscosities
Dynamic viscosities of sucrose water solutions vs. temperature.
Sulfur Dioxide Liquid - Thermal Properties
Sulfuric Acid - Density
Density of sulfuric acid at various temperatures and concentrations.
Supercooled Water - Vapor Pressure vs. Temperature
Undercooled water and vapor pressure.
Surface Emissivity Coefficients
Surface Tension - Water in contact with Air
Surface tension of water in contact with air for temperatures ranging 0 to 100 degC (32 to 212 degF) - in imperial units (BG units) and SI units.
Thermal Expansion - Linear Expansion Coefficients
Linear temperature expansion coefficients for common materials like aluminum, copper, glass, iron and many more.
Thermodynamic Key Values Internationally Agreed
Internationally agreed, internally consistent, values for the thermodynamic properties (standard enthalpy of formation, entropy and [H°(298)-H°(0)]) of key chemical substances.
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
Toluene - Thermophysical Properties
Chemical, physical and thermal properties of toluene, also called methylbenzene, toluol and phenylmethane. Phase diagram included.
Toluene Liquid - Thermal Properties vs. Temperature
U.S. Standard Atmosphere vs. Altitude
Properties of the US standard atmosphere ranging -5000 to 250000 ft altitude.
Universal and Individual Gas Constants
UNS - Unified Numbering System
The Unified Numbering System - UNS - used for metals and alloys.
Valves - Plastic Materials
An introduction to plastic materials used in valves.
Vinyl Ester - Chemical Resistance
Chemical resistance of Vinyl Ester to products as Acetone, Alcohol, Diesel oil and more.
Viscosity - Converting Chart
Water - Boiling Points at Higher Pressures
Water - Boiling Points vs. Altitude
Elevation above sea level and the boiling point of water.
Definitions, online calculator and figures and tables with water properties like density, specific weight and thermal expansion coefficient of liquid water at temperatures ranging 0 to 360°C (32 to 680°F).
Water - Dynamic (Absolute) and Kinematic Viscosity vs. Temperature and Pressure
Water - Heat of Vaporization vs. Temperature
Ionization constant (= dissociation constant = self-ionization constant = ion product = autoprotolysis constant ) of water and heavy water, given as function of temperature (°C and °F) in figures and tables.
Water - Prandtl Number vs. Temperature and Pressure
Figures and tables with Prandtl Number of liquid and gaseous water at varying temperarure and pressure, SI and Imperial units.
Water - Properties vs. Temperature and Pressure
Liquid water properties at temperatures between melting point and boiling point and pressures of 14.7 psia, 1000 psia and 10000 psia (1 atm, 68.1atm and 681 atm).
Water - Saturation Pressure and Specific Weight vs. Temperature
Vapor pressure and specific weight of water at temperatures ranging 32 to 212 oF - Imperial Units.
Water - Saturation Pressure vs. Temperature
Water - Specific Heat vs. Temperature
Water - Speed of Sound vs. Temperature
Speed of sound in water at temperatures ranging 32 - 212°F (0 - 100°C) - Imperial and SI units.
Water Content in Food and other Products
Water content before and after drying - in food and other products cork, grain, soap, peat, wood and more.
Water Vapor - Specific Heat vs. Temperature
Specific heat of Water Vapor - H2O - at temperatures ranging 175 - 6000 K.
Wood - Combustion Heat Values
Combustion of wood and firewood heat values for species like Pine, Elm, Hickory and more.
Wood - Density vs. Moisture Content
The density of wood versus moisture content.
Wood Hardness
Soft and hardwood - the Janka Hardness scale.
Wood Species - Densities
Wrought and Cast Copper Alloys - Properties Database
A searchable database of properties for wrought and cast copper alloys.
Yield Structure of Crude Oils with Increasing Density of Crude
Yields of different crude oil distillation cuts are plotted as function of whole crude specific gravity. Fractions based on European and North American markets, and the typical differences in crude oil fractionation in the two markets are also shown.
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
Boiling Points of Fluids
Densities
Melting and Freezing Points
Viscosities
