Autoprotolysis describes the reaction of water with itself:
2 H2O ↔ H3 O + + OH¯ [1]
and an equlibrium constant can be defined as
K eq = a(H3 O + ) * a(OH - ) / a(H2O)2[2]
where a is the chemical activity of the water ions.
Because most acid–base solutions are typically very dilute, the activity of water is generally approximated as being equal to unity. In dilute aqueous solutions, the activities of the solute particles are approximately equal to their concentrations.
Then, and an autoprotolysis constant or water ionization constant can be defined as
K w = [H3 O + ] [OH¯] [3]
where [H3 O + ] and [OH¯] represents the concentration of H3 O + and OH - ions in water.
Often, a general value of 1.00 x 10¯ 14 is used. However, pK w varies with the temperature as shown in the figures and tables below.
From the chemical equation [1] above, it can be seen that H3 O + and OH¯ concentrations are in the molar ratio of one-to-one. This means that [H3 O + ] = [OH¯]. Therefore the values of [H3 O + ] and [OH¯] can be determined by taking the square root of K w .
Heavy water, D2O, self-ionizes less than normal water, which gives larger pK w values for D2O compared to H2O.
See also other properties of Water at varying temperature and pressure : Boiling points at high pressure , Boiling points at vacuum pressure , Density and specific weight , Dynamic and kinematic viscosity , Enthalpy and entropy , Heat of vaporization , Melting points at high pressure , Prandtl number , Properties at Gas-Liquid Equilibrium Conditions , Saturation pressure , Specific gravity , Specific heat (heat capacity) , Specific volume , Thermal conductivity , Thermal diffusivity and Vapour pressure at gas-liquid equilibrium .
Temperature | Ionization constant, pK w | ||
[°C] | [°F] | H2O | D2O |
0 | 32 | 14.947 | 15.972 |
5 | 41 | 14.734 | 15.743 |
10 | 50 | 14.534 | 15.527 |
15 | 59 | 14.344 | 15.324 |
20 | 68 | 14.165 | 15.132 |
25 | 77 | 13.995 | 14.951 |
30 | 86 | 13.833 | 14.779 |
35 | 95 | 13.680 | 14.616 |
40 | 104 | 13.535 | 14.462 |
45 | 113 | 13.396 | 14.316 |
50 | 122 | 13.265 | 14.176 |
55 | 131 | 13.140 | 14.044 |
60 | 140 | 13.020 | 13.918 |
65 | 149 | 12.907 | 13.798 |
70 | 158 | 12.799 | 13.683 |
75 | 167 | 12.696 | 13.574 |
80 | 176 | 12.598 | 13.470 |
85 | 185 | 12.505 | 13.371 |
90 | 194 | 12.417 | 13.276 |
95 | 203 | 12.332 | 13.186 |
100 | 212 | 12.252 | 13.120 |
150 | 302 | 11.64 | |
200 | 393 | 11.31 | |
250 | 482 | 11.20 | |
300 | 572 | 11.34 | |
350 | 662 | 11.92 |
[°F] | [°C] | H2O | D2O |
32 | 0.0 | 14.947 | 15.972 |
40 | 4.4 | 14.758 | 15.768 |
50 | 10.0 | 14.534 | 15.528 |
60 | 15.6 | 14.324 | 15.302 |
70 | 21.1 | 14.126 | 15.090 |
80 | 26.7 | 13.940 | 14.891 |
90 | 32.2 | 13.764 | 14.705 |
100 | 37.8 | 13.598 | 14.529 |
110 | 43.3 | 13.442 | 14.364 |
120 | 48.9 | 13.293 | 14.208 |
130 | 54.4 | 13.153 | 14.060 |
140 | 60.0 | 13.020 | 13.918 |
150 | 65.6 | 12.895 | 13.785 |
160 | 71.1 | 12.776 | 13.658 |
170 | 76.7 | 12.663 | 13.537 |
180 | 82.2 | 12.556 | 13.423 |
190 | 87.8 | 12.455 | 13.317 |
200 | 93.3 | 12.360 | 13.219 |
210 | 98.9 | 12.270 | 13.13 |
212 | 100.0 | 12.252 | 13.12 |
250 | 121.1 | 11.97 | |
300 | 148.9 | 11.65 | |
400 | 204.4 | 11.29 | |
500 | 260.0 | 11.20 | |
600 | 315.6 | 11.49 | |
650 | 343.3 | 11.84 |
• Steam and Condensate
• Thermodynamics
• Water Systems
Definitions, online calculator and figures and tables with water properties like density, specific weight and thermal expansion coefficient of liquid water at temperatures ranging 0 to 360°C (32 to 680°F).
Water - Dynamic (Absolute) and Kinematic Viscosity vs. Temperature and Pressure
Water - Saturation Pressure vs. Temperature
Water - Specific Heat vs. Temperature
