At the critical point there is no change of state when pressure is increased or if heat is added. At the critical point water and steam can't be distinguished and there is no point referring to water or steam.
The critical point of water is achieved at
- Water vapor pressure of 217.75 atm = 220.64 bar = 22.064 MPa = 3200.1 psi
- Temperature of 647.096 K = 373.946 °C = 705.103 °F
- Critical point density: 0.322 g/cm3 = 0.6248 slug/ft3 = 20.102 lbm /ft3
For states above the critical point the steam is supercritical . Supercritical is not the same as superheated - which is saturated steam at lower pressures and temperatures heated above the saturation temperature.
The triple point of water is at
- Water vapor pressure of 0.00604 atm = 6.12 mbar = 611.657 Pa = 0.08871 psi
- Temperature 273.16 K = 0.01 °C = 32.02 °F
- Triple point density (liquid): 0.99979 g/cm3 = 1.93991 slug/ft3 = 62.4148 lbm /ft3
See Water and Heavy Water - for thermodynamic properties.
See also Water Boiling points at high pressure , Boiling points at vacuum pressure , Density, specific weight and thermal expansion coefficient , Dynamic and kinematic viscosity , Enthalpy and entropy , Heat of vaporization , Ionization Constant, pK w , of normal and heavy water , Melting points at high pressure , Saturation pressure , Specific gravity , Specific heat (heat capacity) and Specific volume for online calculatores, figures and tables showing temperature or pressure dependences of the different properties.
• Steam and Condensate
• Thermodynamics
• Thermodynamics
• Water Systems
Critical Points for some Substances
Critical points of some common substances like air, argon, helium and more
Substances Triple Points
Triple points for common substances.
Superheated Steam - Enthalpy
Enthalpy of steam superheated to temperatures above it's boiling point.
Superheated Steam - Entropy
The entropy of steam superheated to temperatures above saturation points.
Vacuum Pipes - Pressure Loss vs. Air Flow
Calculate pressure drops in vacuum pipe lines.
Water - Boiling Points at Higher Pressures
Definitions, online calculator and figures and tables with water properties like density, specific weight and thermal expansion coefficient of liquid water at temperatures ranging 0 to 360°C (32 to 680°F).
Water - Dynamic (Absolute) and Kinematic Viscosity vs. Temperature and Pressure
Ionization constant (= dissociation constant = self-ionization constant = ion product = autoprotolysis constant ) of water and heavy water, given as function of temperature (°C and °F) in figures and tables.
Water - Saturation Pressure vs. Temperature
Water - Specific Heat vs. Temperature
Water-Steam Mollier Diagram
Wet Steam - Enthalpy
Wet Steam - Quality vs. Dryness Fractions
Introduction and definition of steam quality and dryness fraction including calculating wet steam enthalpy and specific volume.
