Air - Density vs. Pressure and Temperatures
Density is the ratio of the mass to the volume of a substance:
ρ = m/V [1]
ρ = density, units typically [kg/m3 ] or [lb/ft3 ]
m = mass, units typically [kg] or [lb]
V = volume, units typically [m3 ] or [ft3 ]
Tabulated values and density units conversion are given below the figures.
See also Air Composition and molecular weight , Density and specific weight at varying temperature , Diffusion Coefficients for Gases in Air , Dynamic (absolute) and kinematic viscosity , Prandtl Number , Specific heat at varying temperature and Specific heat at varying pressure , Thermal Conductivity , Thermal Diffusivity , Properties at gas-liquid equilibrium conditions and Air thermophysical properties , for other properties of air .
See Density and specific weight o f acetone , ammonia , argon , benzene , butane , carbon dioxide , carbon monoxide , ethane , ethanol , ethylene , helium , hydrogen , methane , methanol , nitrogen , oxygen , pentane , propane , toluene and water , as well as Density of crude oil , Density of fuel oils , Density of lubricating oil and Density of jet fuel as function of temperature.
Figures showing air density at ambient pressures (80-105 kPa, 0.8-1.05 bara, 11.6-15.4 psia) and temperatures:
Figures showing air density as function of gauge pressure (0-20 bar, 0-300 psi) at selected temperatures:
Figures showing air density as function of absolute pressure (1-10 000 bar, 14.5 - 150 000 psia) at selected temperatures:
Weight or density of air ( pounds per cubic foot) for different gauge pressures (psi) :
Gauge pressure | Density of air [lb/ft3 ] at different temperatures [°F] | ||||||||||||||||
[psi] | 30 | 40 | 50 | 60 | 70 | 80 | 90 | 100 | 120 | 140 | 150 | 200 | 250 | 300 | 400 | 500 | 600 |
0 |
0.081 | 0.080 | 0.078 | 0.076 | 0.075 | 0.074 | 0.072 | 0.071 | 0.069 | 0.066 | 0.065 | 0.060 | 0.056 | 0.052 | 0.046 | 0.041 | 0.038 |
5 | 0.109 | 0.107 | 0.105 | 0.102 | 0.101 | 0.099 | 0.097 | 0.095 | 0.092 | 0.089 | 0.087 | 0.081 | 0.075 | 0.070 | 0.062 | 0.056 | 0.05 |
10 | 0.136 | 0.134 | 0.131 | 0.128 | 0.126 | 0.124 | 0.121 | 0.119 | 0.115 | 0.111 | 0.109 | 0.101 | 0.094 | 0.088 | 0.078 | 0.070 | 0.063 |
20 | 0.192 | 0.188 | 0.185 | 0.180 | 0.177 | 0.174 | 0.171 | 0.168 | 0.162 | 0.156 | 0.154 | 0.142 | 0.132 | 0.123 | 0.109 | 0.098 | 0.089 |
30 | 0.247 | 0.242 | 0.238 | 0.232 | 0.228 | 0.224 | 0.220 | 0.216 | 0.208 | 0.201 | 0.198 | 0.183 | 0.170 | 0.159 | 0.141 | 0.126 | 0.114 |
40 | 0.302 | 0.295 | 0.291 | 0.284 | 0.279 | 0.274 | 0.269 | 0.264 | 0.255 | 0.246 | 0.242 | 0.225 | 0.208 | 0.195 | 0.172 | 0.154 | 0.140 |
50 | 0.357 | 0.350 | 0.344 | 0.336 | 0.330 | 0.324 | 0.318 | 0.312 | 0.302 | 0.291 | 0.287 | 0.265 | 0.246 | 0.23 | 0.203 | 0.182 | 0.165 |
60 | 0.412 | 0.404 | 0.397 | 0.388 | 0.381 | 0.374 | 0.367 | 0.361 | 0.348 | 0.337 | 0.331 | 0.306 | 0.284 | 0.266 | 0.235 | 0.210 | 0.190 |
70 | 0.467 | 0.458 | 0.451 | 0.440 | 0.432 | 0.424 | 0.416 | 0.409 | 0.395 | 0.382 | 0.375 | 0.347 | 0.322 | 0.301 | 0.266 | 0.238 | 0.216 |
80 | 0.522 | 0.512 | 0.504 | 0.492 | 0.483 | 0.474 | 0.465 | 0.457 | 0.441 | 0.427 | 0.420 | 0.388 | 0.361 | 0.337 | 0.298 | 0.267 | 0.241 |
90 | 0.578 | 0.566 | 0.557 | 0.544 | 0.534 | 0.524 | 0.515 | 0.505 | 0.488 | 0.472 | 0.464 | 0.429 | 0.399 | 0.372 | 0.329 | 0.295 | 0.267 |
100 | 0.633 | 0.620 | 0.610 | 0.596 | 0.585 | 0.574 | 0.564 | 0.554 | 0.535 | 0.517 | 0.508 | 0.470 | 0.437 | 0.408 | 0.360 | 0.323 | 0.292 |
120 | 0.743 | 0.728 | 0.717 | 0.700 | 0.687 | 0.674 | 0.662 | 0.650 | 0.628 | 0.607 | 0.597 | 0.552 | 0.513 | 0.479 | 0.423 | 0.379 | 0.343 |
140 | 0.853 | 0.836 | 0.823 | 0.804 | 0.789 | 0.774 | 0.760 | 0.747 | 0.721 | 0.697 | 0.686 | 0.634 | 0.589 | 0.550 | 0.486 | 0.436 | 0.394 |
150 | 0.909 | 0.890 | 0.876 | 0.856 | 0.840 | 0.824 | 0.809 | 0.795 | 0.768 | 0.742 | 0.730 | 0.675 | 0.627 | 0.586 | 0.518 | 0.464 | 0.420 |
200 | 1.185 | 1.161 | 1.142 | 1.116 | 1.095 | 1.075 | 1.055 | 1.036 | 1.001 | 0.967 | 0.951 | 0.879 | 0.817 | 0.764 | 0.675 | 0.604 | 0.547 |
250 | 1.46 | 1.431 | 1.408 | 1.376 | 1.350 | 1.325 | 1.301 | 1.278 | 1.234 | 1.193 | 1.173 | 1.084 | 1.008 | 0.941 | 0.832 | 0.745 | 0.675 |
300 | 1.736 | 1.702 | 1.674 | 1.636 | 1.605 | 1.575 | 1.547 | 1.519 | 1.467 | 1.418 | 1.395 | 1.289 | 1.198 | 1.119 | 0.989 | 0.886 | 0.802 |
400 | 2.29 | 2.24 | 2.21 | 2.16 | 2.12 | 2.08 | 2.04 | 2.00 | 1.933 | 1.868 | 1.838 | 1.698 | 1.579 | 1.475 | 1.303 | 1.167 | 1.057 |
500 | 2.84 | 2.78 | 2.74 | 2.68 | 2.63 | 2.58 | 2.53 | 2.48 | 2.4 | 2.32 | 2.28 | 2.11 | 1.959 | 1.83 | 1.618 | 1.449 | 1.312 |
700 | 3.94 | 3.86 | 3.8 | 3.72 | 3.65 | 3.58 | 3.51 | 3.45 | 3.33 | 3.22 | 3.17 | 2.93 | 2.72 | 2.54 | 2.25 | 2.01 | 1.822 |
800 | 4.49 | 4.4 | 4.33 | 4.24 | 4.16 | 4.08 | 4.00 | 3.93 | 3.8 | 3.67 | 3.61 | 3.34 | 3.1 | 2.9 | 2.56 | 2.29 | 2.08 |
900 | 5.05 | 4.95 | 4.87 | 4.76 | 4.67 | 4.58 | 4.50 | 4.42 | 4.26 | 4.12 | 4.05 | 3.75 | 3.48 | 3.25 | 2.87 | 2.58 | 2.33 |
1000 | 5.6 | 5.49 | 5.4 | 5.28 | 5.18 | 5.08 | 4.99 | 4.9 | 4.73 | 4.57 | 4.5 | 4.16 | 3.86 | 3.61 | 3.19 | 2.86 | 2.59 |
Weight or density of air ( kilograms per cubic meter) for different gauge pressures (bar) :
Gauge pressure | Density of air [kg/m3 ] at different temperatures [°C] | ||||||||||||||||
[bar] | -1.1 | 4.4 | 10.0 | 15.6 | 21.1 | 26.7 | 32.2 | 37.8 | 48.9 | 60.0 | 65.6 | 93.3 | 121.1 | 148.9 | 204.4 | 260.0 | 315.6 |
0.00 | 1.30 | 1.28 | 1.25 | 1.22 | 1.20 | 1.19 | 1.15 | 1.14 | 1.11 | 1.06 | 1.04 | 0.96 | 0.90 | 0.83 | 0.74 | 0.66 | 0.61 |
0.34 | 1.75 | 1.71 | 1.68 | 1.63 | 1.62 | 1.59 | 1.55 | 1.52 | 1.47 | 1.43 | 1.39 | 1.30 | 1.20 | 1.12 | 0.99 | 0.90 | 0.80 |
0.69 | 2.18 | 2.15 | 2.10 | 2.05 | 2.02 | 1.99 | 1.94 | 1.91 | 1.84 | 1.78 | 1.75 | 1.62 | 1.51 | 1.41 | 1.25 | 1.12 | 1.01 |
1.38 | 3.08 | 3.01 | 2.96 | 2.88 | 2.84 | 2.79 | 2.74 | 2.69 | 2.59 | 2.50 | 2.47 | 2.27 | 2.11 | 1.97 | 1.75 | 1.57 | 1.43 |
2.07 | 3.96 | 3.88 | 3.81 | 3.72 | 3.65 | 3.59 | 3.52 | 3.46 | 3.33 | 3.22 | 3.17 | 2.93 | 2.72 | 2.55 | 2.26 | 2.02 | 1.83 |
2.72 | 4.84 | 4.73 | 4.66 | 4.55 | 4.47 | 4.39 | 4.31 | 4.23 | 4.08 | 3.94 | 3.88 | 3.60 | 3.33 | 3.12 | 2.76 | 2.47 | 2.24 |
3.45 | 5.72 | 5.61 | 5.51 | 5.38 | 5.29 | 5.19 | 5.09 | 5.00 | 4.84 | 4.66 | 4.60 | 4.24 | 3.94 | 3.68 | 3.25 | 2.92 | 2.64 |
4.14 | 6.60 | 6.47 | 6.36 | 6.22 | 6.10 | 5.99 | 5.88 | 5.78 | 5.57 | 5.40 | 5.30 | 4.90 | 4.55 | 4.26 | 3.76 | 3.36 | 3.04 |
4.83 | 7.48 | 7.34 | 7.22 | 7.05 | 6.92 | 6.79 | 6.66 | 6.55 | 6.33 | 6.12 | 6.01 | 5.56 | 5.16 | 4.82 | 4.26 | 3.81 | 3.46 |
5.52 | 8.36 | 8.20 | 8.07 | 7.88 | 7.74 | 7.59 | 7.45 | 7.32 | 7.06 | 6.84 | 6.73 | 6.22 | 5.78 | 5.40 | 4.77 | 4.28 | 3.86 |
6.21 | 9.26 | 9.07 | 8.92 | 8.71 | 8.55 | 8.39 | 8.25 | 8.09 | 7.82 | 7.56 | 7.43 | 6.87 | 6.39 | 5.96 | 5.27 | 4.73 | 4.28 |
6.89 | 10.14 | 9.93 | 9.77 | 9.55 | 9.37 | 9.19 | 9.03 | 8.87 | 8.57 | 8.28 | 8.14 | 7.53 | 7.00 | 6.54 | 5.77 | 5.17 | 4.68 |
8.27 | 11.90 | 11.66 | 11.49 | 11.21 | 11.00 | 10.80 | 10.60 | 10.41 | 10.06 | 9.72 | 9.56 | 8.84 | 8.22 | 7.67 | 6.78 | 6.07 | 5.49 |
9.65 | 13.66 | 13.39 | 13.18 | 12.88 | 12.64 | 12.40 | 12.17 | 11.97 | 11.55 | 11.16 | 10.99 | 10.16 | 9.43 | 8.81 | 7.78 | 6.98 | 6.31 |
10.34 | 14.56 | 14.26 | 14.03 | 13.71 | 13.46 | 13.20 | 12.96 | 12.73 | 12.30 | 11.89 | 11.69 | 10.81 | 10.04 | 9.39 | 8.30 | 7.43 | 6.73 |
13.79 | 18.98 | 18.60 | 18.29 | 17.88 | 17.54 | 17.22 | 16.90 | 16.60 | 16.03 | 15.49 | 15.23 | 14.08 | 13.09 | 12.24 | 10.81 | 9.68 | 8.76 |
17.24 | 23.39 | 22.92 | 22.55 | 22.04 | 21.62 | 21.22 | 20.84 | 20.47 | 19.77 | 19.11 | 18.79 | 17.36 | 16.15 | 15.07 | 13.33 | 11.93 | 10.81 |
20.68 | 27.81 | 27.26 | 26.81 | 26.21 | 25.71 | 25.23 | 24.78 | 24.33 | 23.50 | 22.71 | 22.35 | 20.65 | 19.19 | 17.92 | 15.84 | 14.19 | 12.85 |
27.58 | 36.68 | 35.88 | 35.40 | 34.60 | 33.96 | 33.32 | 32.68 | 32.04 | 30.96 | 29.92 | 29.44 | 27.20 | 25.29 | 23.63 | 20.87 | 18.69 | 16.93 |
34.47 | 45.49 | 44.53 | 43.89 | 42.93 | 42.13 | 41.33 | 40.53 | 39.73 | 38.44 | 37.16 | 36.52 | 33.80 | 31.38 | 29.31 | 25.92 | 23.21 | 21.02 |
48.26 | 63.11 | 61.83 | 60.87 | 59.59 | 58.47 | 57.35 | 56.22 | 55.26 | 53.34 | 51.58 | 50.78 | 46.93 | 43.57 | 40.69 | 36.04 | 32.20 | 29.19 |
55.16 | 71.92 | 70.48 | 69.36 | 67.92 | 66.64 | 65.36 | 64.07 | 62.95 | 60.87 | 58.79 | 57.83 | 53.50 | 49.66 | 46.45 | 41.01 | 36.68 | 33.32 |
62.05 | 80.89 | 79.29 | 78.01 | 76.25 | 74.81 | 73.36 | 72.08 | 70.80 | 68.24 | 66.00 | 64.87 | 60.07 | 55.74 | 52.06 | 45.97 | 41.33 | 37.32 |
68.95 | 89.70 | 87.94 | 86.50 | 84.58 | 82.98 | 81.37 | 79.93 | 78.49 | 75.77 | 73.20 | 72.08 | 66.64 | 61.83 | 57.83 | 51.10 | 45.81 | 41.49 |
kilogram/cubic meter [kg/m3 ] = gram/liter [g/l], kilogram/liter [kg/l] = gram/cubic centimeter [g/cm3 ]= ton(metric)/cubic meter [t/m3 ], once/gallon(US liquid) [oz/gal(US liq)] pound/cubic inch [lb/in3 ], pound/cubic foot [lb/ft3 ], pound/gallon(UK) [lb/gal(UK)], pound/gallon(US liquid) [lb/gal(US liq)], slug/cubic foot [sl/ft3 ], ton(short)/cubic yard [ton(short)/yd3 ], ton(long)/cubic yard [yd3 ]
Examples
The density of air can be calculated as
ρ = 1.325 p in Hg / T R
= 2.7 p psia / T R
= 2.7 (p psig + 14.7) / (T F + 459.7) (1)
ρ = density (lb/ft3 )
p in Hg = absolute pressure (inches Hg)
T R = absolute temperature (Rankine)
p psia = absolute pressure (psia)
p psig = gage pressure (psig)
T F = temperature ( oF)
Example - Weight of Air
The density of air at pressure 29.92 inches Hg at 100 degrees F can be calculated as
ρ = 1.325 ( 29.92 inches Hg ) / ((100 oF) + 459.7)
= 0.0708 lb/ft3
The weight of 10 ft3 air can be calculated as
W = (10 ft3 ) (0.071 lb/ft3 )
= 0.708 lb
• Air Psychrometrics
• Densities
• Gases and Compressed Air
Density and specific volume of air varies with elevation above sea level.
Air - Dynamic and Kinematic Viscosity
Air - Humidity Ratio
Air - Prandtl Number
Air - Specific Heat vs. Temperature at Constant Pressure
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Thermal properties of air at different temperatures - density, viscosity, critical temperature and pressure, triple point, enthalpi and entropi, thermal conductivity and diffusivity and more.
Air Conditioning - Cooling of Air and Condensate Generated
Water may condensate when air is cooled in air conditioning systems.
Pressure loss in compressed air pipe lines.
An introduction to density, specific weight and specific gravity.
Dry Air - Thermodynamic and Physical Properties
Thermodynamic properties of dry air - specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Weight of Water Vapor
Weight of water vapor in air
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
Wind Power
Power generation from wind.
