Solubility Product Constants
For ionic compounds with limited solubility in water, an equilibrium constant, K sp , can be defined from the ion concentration in water from the equation:
M m A n (s) = m M n+ (aq) + n A m- (aq)
where M m A n is the slightly soluble substance and M n+ and A m- are the ions produced in solution by dissosiation of M m A n .
K sp = [M n+ ] m * [A m- ] n
The table below gives calculated values of K sp for common ionic substances at 25°C (77°F). They are calculated by using standard state thermodynamic data and the equations:
Δ G° = m *Δf G °(M + , aq) + n *Δf G° (A - , aq) - Δf G° (M m A n , s) and ln K sp = -Δ G°/RT
K sp is indicating the maximum concentration of the solved ionic substace in water at the actual (stable) temperature.
For sulfides , a K spa is defined based on the equation
M m S n (s) + 2H + = m M + (aq) + n H2S(aq)
See also Solutions, molarity and dilution , and Solubility guidelines for ionic compounds in water
Name | Formula | K sp | K spa |
Aluminium hydroxide | Al(OH)3 | 3*10 -34 | |
Aluminium phosphate | AlPO 4 | 9.84 *10 -21 | |
Barium bromate | Ba(BrO3 ) 2 | 2.43*10-4 | |
Barium carbonate | BaCO3 | 2.58*10 -9 | |
Barium chromate(VI) | BaCrO 4 | 1.17*10 -10 | |
Barium fluoride | BaF 2 | 1.84*10 -7 | |
Barium hydroxide octahydrate | Ba(OH)2*8H2O | 2.55*10-4 | |
Barium iodate | Ba(IO3 ) 2 | 4.01 *10 -9 | |
Barium iodate monohydrate | Ba(IO3 )2*H2O | 1.67 *10 -9 | |
Barium molybdate | BaMoO 4 | 3.54*10 -8 | |
Barium nitrate | Ba(NO3 ) 2 | 4.64*10-3 | |
Barium selenate | BaSeO 4 | 3.40*10 -8 | |
Barium sulfate | BaSO 4 | 1.08*10 -10 | |
Barium sulfite | BaSO3 | 5.0*10 -10 | |
Beryllium hydroxide | Be(OH) 2 | 6.92*10 -22 | |
Bismuth arsenate | BiAsO 4 | 4.43*10 -10 | |
Bismuth iodide | BiI | 7.71*10-19 | |
Bismuth triiodite | BiI3 | 7.71*10-19 | |
Cadmium arsenate | Cd3 (AsO 4 ) 2 | 2.2*10 -33 | |
Cadmium carbonate | CdCO3 | 1.0*10-12 | |
Cadmium fluoride | CdF 2 | 6.44 *10-3 | |
Cadmium hydroxide | Cd(OH) 2 | 7.2*10 -15 | |
Cadmium iodate | Cd(IO3 ) 2 | 2.5*10 -8 | |
Cadmium oxalate trihydrate | CdC2O 4 *3H2O | 1.42*10 -8 | |
Cadmium phosphate | Cd3 (PO 4 ) 2 | 2.53*10 -33 | |
Cadmium sulfide | CdS | 8*10 -7 | |
Calcium carbonate (calcite) | CaCO3 | 3.36*10 -9 | |
Calcium carbonate (aragonite) | CaCO3 | 6.0*10 -9 | |
Calcium fluoride | CaF 2 | 3.45*10 -11 | |
Calcium hydroxide | Ca(OH) 2 | 5.02*10-6 | |
Calcium iodate | Ca(IO3 ) 2 | 6.47*10-6 | |
Calcium iodate hexahydrate | Ca(IO3 )2*6H2O | 7.10 *10 -7 | |
Calcium molybdate | CaMoO 4 | 1.46*10 -8 | |
Calcium oxalate monohydrate | CaC2O 4 *H2O | 2.32*10 -9 | |
Calcium phosphate | Ca3 (PO 4 ) 2 | 2.07*10 -33 | |
Calcium sulfate | CaSO 4 | 4.93*10 -5 | |
Calcium sulfate dihydrate | CaSO 4 *2H2O | 3.14 *10 -5 | |
Calcium sulfite hemihydrate | CaSO3 *0.5H2O | 3.1 *10 -7 | |
Cesium perchlorate | CsClO 4 | 3.95*10-3 | |
Cesium periodate | CsIO 4 | 5.16 *10-6 | |
Cobalt(II) arsenate | Co3 (AsO 4 ) 2 | 6.80 *10 -29 | |
Cobalt(II) carbonate | CoCO3 | 1.0 *10 -10 | |
Cobalt(II) hydroxide | Co(OH) 2 | 5.92*10 -15 | |
Cobalt(II) iodate dihydrate | Co(IO3 )2*2H2O | 1.21*10-2 | |
Cobalt(II) phosphate | Co3 (PO 4 ) 2 | 2.05*10 -35 | |
Copper(II) arsenate | Cu3 (AsO 4 ) 2 | 7.95*10 -36 | |
Copper(I) bromide | CuBr | 6.27*10 -9 | |
Copper(I) chloride | CuCl | 1.72*10 -7 | |
Copper(I) cyanide | CuCN | 3.47 *10 -20 | |
Copper(II) hydroxide | Cu(OH) 2 | 1*10 -20 | |
Copper(II) iodate monohydrate | Cu(IO3 )2*H2O | 6.94 *10 -8 | |
Copper(I) iodide | CuI | 1.27*10-12 | |
Copper(II) oxalate | CuC2O 4 | 4.43*10 -10 | |
Copper(II) phosphate | Cu3 (PO 4 ) 2 | 1.40*10 -37 | |
Copper(II) sulfide | CuS | 6*10 -16 | |
Copper(I) thiocyanate | CuSCN | 1.77*10 -13 | |
Chromium(II)hydroxide | Cr(OH) 2 | 1*10 -17 | |
Chromium(III)hydroxide | Cr(OH)3 | 1*10 -30 | |
Europium(III) hydroxide | Eu(OH)3 | 9.38 *10 -27 | |
Gallium(III) hydroxide | Ga(OH)3 | 7.38 *10 -36 | |
Iron(II) carbonate | FeCO3 | 3.13 *10 -11 | |
Iron(II) fluoride | FeF 2 | 2.36*10-6 | |
Iron(II) hydroxide | Fe(OH) 2 | 4.87*10 -17 | |
Iron(III) hydroxide | Fe(OH)3 | 2.79*10 -39 | |
Iron(III) phosphate dihydrate | FePO 4 *2H2O | 9.91*10 -16 | |
Iron(II) sulfide | FeS | 6*102 | |
Lanthanum iodate | La(IO3 )3 | 7.50*10-12 | |
Lead(II) bromide | PbBr 2 | 6.60*10-6 | |
Lead(II) carbonate | PbCO3 | 7.40*10 -14 | |
Lead(II) chloride | PbCl 2 | 1.70*10 -5 | |
Lead(II) chromate | PbCrO 4 | 3*10 -13 | |
Lead(II) fluoride | PbF 2 | 3.3*10 -8 | |
Lead(II) hydroxide | Pb(OH) 2 | 1.43*10 -20 | |
Lead(II) iodate | Pb(IO3 ) 2 | 3.69*10 -13 | |
Lead(II) iodide | PbI 2 | 9.8*10 -9 | |
Lead oxalate | PbC2O 4 | 8.5*10 -9 | |
Lead(II) selenate | PbSeO 4 | 1.37*10 -7 | |
Lead(II) sulfate | PbSO 4 | 2.53*10 -8 | |
Lead(II) sulfide | PbS | 3*10 -7 | |
Lithium carbonate | LiCO3 | 8.15*10-4 | |
Lithium fluoride | LiF | 1.84*10-3 | |
Lithium phosphate | Li3 PO 4 | 2.37*10 -11 | |
Magnesium ammonium phosphate | MgNH 4 PO 4 | 3*10 -13 | |
Magnesium carbonate | MgCO3 | 6.82*10-6 | |
Magnesium carbonate pentahydrate | MgCO3 *5H2O | 3.79*10-6 | |
Magnesium carbonate trihydrate | MgCO3 *3H2O | 2.38*10-6 | |
Magnesium fluoride | MgF 2 | 5.16*10 -11 | |
Magnesium hydroxide | Mg(OH) 2 | 5.61*10-12 | |
Magnesium oxalate dihydrate | MgC2O 4 *2H2O | 4.83*10-6 | |
Magnesium phosphate | Mg3 (PO 4 ) 2 | 1.04*10 -24 | |
Manganese(II) carbonate | MnCO3 | 2.24*10 -11 | |
Manganese(II) iodate | Mn(IO3 ) 2 | 4.37*10 -7 | |
Manganese(II) oxalate dihydrate | MnC2O4*2H2O | 1.70*10 -7 | |
Manganese(II) sulfide (a-form) | MnS | 3*10 7 | |
Mercury(I) bromide | Hg2Br 2 | 6.40*10 -23 | |
Mercury(II) bromide | HgBr3 | 6.2*10 -20 | |
Mercury(I) carbonate | Hg2CO3 | 3.6*10 -17 | |
Mercury(I) chloride | Hg2Cl 2 | 1.43*10 -18 | |
Mercury(I) fluoride | Hg2F 2 | 3.10*10-6 | |
Mercury(I)hydroxide | Hg2(OH) 2 | 2*10 -24 | |
Mercury(II) hydroxide | Hg(OH) 2 | 4*10 -26 | |
Mercury(I) iodide | Hg2I 2 | 5.2*10 -29 | |
Mercury(II) iodide (red) | HgI 2 | 2.9*10 -29 | |
Mercury(I) oxalate | Hg2C2O 4 | 1.75*10 -13 | |
Mercury(I) sulfate | Hg2SO 4 | 6.5*10 -7 | |
Mercury(II) sulfide (red) | Hg2S | 4*10 -33 | |
Mercury(II) sulfide (black) | Hg2S | 2*10 -32 | |
Mercury(I) thiocyanate | Hg2(SCN) 2 | 3.2*10 -20 | |
Neodymium carbonate | Nd2(CO3 )3 | 1.08*10 -33 | |
Nickel(II) carbonate | NiCO3 | 1.42*10 -7 | |
Nickel(II) hydroxide | Ni(OH) 2 | 5.48*10 -16 | |
Nickel(II) iodate | Ni(IO3 ) 2 | 4.71*10 -5 | |
Nickel(II) phosphate | Ni3 (PO 4 ) 2 | 4.74*10 -32 | |
Palladium(II) thiocyanate | Pd(SCN) 2 | 4.39*10 -23 | |
Potassium hexachloroplatinate | K2PtCl6 | 7.48*10-6 | |
Potassium perchlorate | KClO 4 | 1.05*10-2 | |
Potassium periodate | KIO 4 | 3.71*10-4 | |
Praseodymium(III) hydroxide | Pr(OH)3 | 3.39*10 -24 | |
Radium iodate | Ra(IO3 ) 2 | 1.16*10 -9 | |
Radium sulfate | RaSO 4 | 3.66*10 -11 | |
Rubidium perchlorate | RbClO 4 | 3.00*10-3 | |
Scandium fluoride | ScF3 | 5.81*10 -24 | |
Scandium hydroxide | Sc(OH)3 | 2.22*10 -31 | |
Silver(I) acetate | AgC2H3 O 2 | 1.94*10-3 | |
Silver(I) arsenate | Ag3 AsO 4 | 1.03*10 -22 | |
Silver(I) bromate | AgBrO3 | 5.38*10 -5 | |
Silver(I) bromide | AgBr | 5.35*10 -13 | |
Silver(I) carbonate | Ag2CO3 | 8.46*10-12 | |
Silver(I) chloride | AgCl | 1.77*10 -10 | |
Silver(I) chromate | Ag2CrO 4 | 1.12*10-12 | |
Silver(I) cyanide | AgCN | 5.97*10 -17 | |
Silver(I) hydroxide | AgOH | 2*10 -8 | |
Silver(I) iodate | AgIO3 | 3.17*10 -8 | |
Silver(I) iodide | AgI | 8.52*10 -17 | |
Silver(I) oxalate | Ag2C2O 4 | 5.40*10-12 | |
Silver(I) phosphate | Ag3 PO 4 | 8.89*10 -17 | |
Silver(I) sulfate | Ag2SO 4 | 1.20*10 -5 | |
Silver(I) sulfide | Ag2S | 6*10 -30 | |
Silver(I) sulfite | Ag2SO3 | 1.50*10 -14 | |
Silver(I) thiocyanate | AgSCN | 1.03*10-12 | |
Strontium arsenate | Sr3 (AsO 4 ) | 4.29*10-19 | |
Strontium carbonate | SrCO3 | 5.60*10 -10 | |
Strontium fluoride | SrF 2 | 4.33*10 -9 | |
Strontium iodate | Sr(IO3 ) 2 | 1.14*10 -7 | |
Strontium iodate hexahydrate | Sr(IO3 )2*6H2O | 4.55*10 -7 | |
Strontium iodate monohydrate | Sr(IO3 )2*H2O | 3.77*10 -7 | |
Strontium oxalate | SrC2O 4 | 5*10 -8 | |
Strontium sulfate | SrSO 4 | 3.44*10 -7 | |
Thallium(I) bromate | TlBrO3 | 1.10*10-4 | |
Thallium(I) bromide | TlBr | 3.71*10-6 | |
Thallium(I) chloride | TlCl | 1.86*10-4 | |
Thallium(I) chromate | Tl2CrO 4 | 8.67*10 -13 | |
Thallium(III) hydroxide | Tl(OH)3 | 1.68*10 -44 | |
Thallium(I) iodate | TlIO3 | 3.12*10-6 | |
Thallium(I) iodine | TlI | 5.54*10 -8 | |
Thallium(I) thiocyanate | TlSCN | 1.57*10-4 | |
Tin(II) hydroxide | Sn(OH) 2 | 5.45*10 -27 | |
Tin(II) sulfide | SnS | 1*10 -5 | |
Vanadium(II) hydroxide | V(OH) 2 | 4*10 -16 | |
Vanadium(III) hydroxide | V(OH)3 | 4*10 -35 | |
Yttrium carbonate | Y2(CO3 )3 | 1.03*10 -31 | |
Yttrium fluoride | YF3 | 8.62*10 -21 | |
Yttrium hydroxide | Y(OH)3 | 1.00*10 -22 | |
Yttrium iodate | Y(IO3 )3 | 1.12*10 -10 | |
Zinc arsenate | Zn3 (AsO 4 ) 2 | 2.8*10 -28 | |
Zinc carbonate | ZnCO3 | 1.46*10 -10 | |
Zinc carbonate monohydrate | ZnCO3 *H2O | 5.42*10 -11 | |
Zinc fluoride | ZnF 2 | 3.04*10-2 | |
Zinc hydroxide | Zn(OH) 2 | 3*10 -17 | |
Zinc iodate dihydrate | Zn(IO3 )2*2H2O | 4.1*10-6 | |
Zinc oxalate dihydrate | ZnC2O 4 *2H2O | 1.38*10 -9 | |
Zinc selenide | ZnSe | 3.6*10 -26 | |
Zinc selenite monohydrate | ZnSeO3 *H2O | 1.59*10 -7 | |
Zinc sulfide (sphalerite) | ZnS | 2*10-4 | |
Zinc sulfide (wurtzite) | ZnS | 3*10-2 |
Concentration Units Converter
Calculator and formulas for conversion between different units of concentration: Molarity, molality, mole fraction, weight percent of solute and grams of solute per liter of solution - descriptive terms for solubility.
Ionic Compounds in Water - Solubility Guidelines
Guidelines or solubility rules to predict whether or not a given ionic compound is soluble in water at room temperature.
Mixtures, Solutions and Suspensions
Mixtures vs. solutions vs. suspensions.
Naming Inorganic Binary Compounds
Rules for naming inorganic ionic and covalent types of chemical compounds.
Salinity of Water
Salinity - salt content - of fresh, brackish and sea water.
Solubility
The amount of a solute that can be dissolved in a solvent.
Solutions, Molarity and Dilution
Definitions and examples of how to calculate wt%, molarity and how to prepare dilutions.
Sugar Solubility in Water
Solubility of sugar in water.
