Some common acids as sulfuric, acetic and more
Temperature, density, specific heat, thermal conductivity, expansion coefficient, kinematic viscosity and Prandtl's number for temperatures ranging -150 - 400 oC
Some common bases as sodium hydroxide, ammonia and more
The Beaufort description and observation of wind and wind velocity
Common bio fuels and their energy content
Units of biomass energy - converting values
Energy stored and potential power generated from capacitors
Exposure health effects of Carbon Monoxide - CO
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy
Earthquake Scales - Richter Magnitude, Moment Magnitude and Mercalli Intensity
Energy balance and energy payback ratio
Ethanol Bio-fuel production from common raw materials
Approximate pH values for some common food products as apples, butter, wines and more ..
Convert between common fossil fuels units
Emission of Nitrogen Oxides - NOx - when combustion fuels like oil, coal, propane and more
Scale for rating tornado intensity
Optical properties of some commonly used glazing materials
Saffir-Simpson damage potential scale for hurricanes
Water - power, head and flow rate
Thermal and thermodynamic properties of ice - density, thermal conductivity and specific heat at temperatures from 0 to -100 oC
Refrigerants - Ozone Depletion (ODP) and Global Warming Potential (GWP)
Water salinity of fresh, brackish and sea water
Daily total solar surface energy
Standard and industrial heating degree-days
Thermal properties of water - density, freezing temperature, boiling temperature, latent heat of melting, latent heat of evaporation, critical temperature and more
The cooling or "chilled" temperature of air in movement - the wind chill index
Available wind energy
Power generated from the wind
Wind is slowed down at the surface by trees and obstructions
Online wind turbine calculator
9 11 11
