The Engineering ToolBox Web Google
Piping Systems - Heat Loss and Insulation
Heat loss from pipes, tubes and tanks - with and without insulation - foam, fiberglass, rockwool and more
Arithmetic Mean Temperature Difference - AMTD - and Logarithmic Mean Temperature Difference - LMTD - formulas with examples - Online Mean Temperature Calculator
Conductive Heat Transfer
Heat transfer takes place as conduction if there is a temperature gradient in a solid or fluid
Convective Heat Transfer
Heat transfer between a solid and a moving fluid is called convection. This is a short tutorial about convective heat transfer
Copper Pipes - Heat Loss
Heat loss from copper tubes at various temperature differences between tube and air
Copper Pipes - Insulation and Heat Loss
Heat loss to surrounding air from insulated copper tubes
Heat Loss Calculator
Online heat loss calculator for pipes and tubes
Heat Loss Diagrams of Insulated Pipes
Heat loss (W/m) diagrams for insulated pipes - ranging 1/2 - 6 inches - insulation thickness 10 - 80 mm - temperature differences 20 - 180 deg C
Heat loss (W/ft) diagrams for insulated pipes - ranging 1/2 - 6 inches - insulation thickness 0.5 - 4 inches - temperature difference 50 - 350 deg F
Heat Loss of Uninsulated Copper Pipes
Heat loss from uninsulated copper pipes ranging 1/2 - 4 inches
Heat Losses from Bare Surfaces
Heat losses from bare surfaces - surface temperatures in deg F and deg C
Heat Transfer Coefficients for Submerged Coils
Heat transfer coefficients for steam and hot water coils submerged in oil tanks
Insulation Materials and Temperature Ranges
Temperature limits of some common insulation materials
Oil Tanks and Heat Loss
Heat loss from lagged and unlagged, sheltered and exposed oil tanks
Overall Heat Transfer Coefficient
Calculate overall heat transfer coefficient - walls or heat exchangers
Perlite Insulation
Thermal conductivity - temperature and k-values
Pipes and Tubes - Recommended Insulation Thickness
Insulation thickness of heating systems - hot water - low, medium and high pressure steam - systems
Polyurethane Insulation
Radiation Emissivity of some common Materials
Radiation emissivity of some common materials - Water, Ice, Snow, Grass ..
Radiation Heat Transfer
Heat transfer due to emission of electromagnetic waves is known as thermal radiation
Steel Pipes and Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions ranging 1/2 - 12 inches
Search the ToolBox
9 12 8
handheld Engineering ToolBox - optimized for mobile devices! 3D Engineering ToolBox - draw and model technical applications!
Resources, Tools and Basic Information  for Engineering and Design of Technical Applications!
