Piping - Recommended Insulation Thickness
Recommended insulation thickness for heating systems like hot water and low, medium or high pressure steam systems.
To avoid heat loss and reduced system efficiency - pipe work in heating systems should always be insulated. Very hot systems, like hot water and steam systems should also be insulated to avoid potential personal injuries.
The table below indicates recommended insulation thickness.
Nominal Pipe Size
NPS
(inches)
Insulation Thickness (inches)*
Temperature Range (oC)
50 - 9090 - 120120 - 150150 - 230
Temperature Range (oF)
120 - 200201 - 250251 - 305306 - 450
Hot WaterLow Pressure SteamMedium Pressure SteamHigh Pressure Steam
< 1" 1.0 1.5 2.0 2.5
1 1/4" - 2" 1.0 1.5 2.5 2.5
2 1/2" - 4" 1.5 2.0 2.5 3.0
5" - 6" 1.5 2.0 3.0 3.5
> 8" 1.5 2.0 3.0 3.5
* based on insulation with thermal resistivity in the range 4 - 4.6 ft2 hr oF/ Btu in (typical for mineral wool at room temperature)
  • 1 inch = 25.4 mm
  • Heat Loss and Insulation
  • Insulation
  • The Engineering ToolBox (2003). Piping - Recommended Insulation Thickness. [online] Available at: https://www.engineeringtoolbox.com/pipes-insulation-thickness-d_16.html [Accessed Day Month Year].
