Thermal resistance is the ability of a material to resist flow of heat. Thermal resistivity is the reciprocal of thermal conductivity and can be expressed as
r = 1 / k (1)
r = thermal resistivity (moC/W, hr ft2 oF/(Btu in))
k = thermal conductivity (W/(moC), Btu in/(hr ft2 oF))
Thermal conductivity - k - is the property of a material indicating its ability to conduct heat.
Thermodynamics
Online calculators, figures and tables showing thermal conductivity of liquid and gaseous butane, C4H10, at varying temperature and pressure, SI and Imperial units. -
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values. -
Carnot Efficiency
The efficiency of the Carnot cycle. -
Conductive Heat Transfer
Online calculator, figures and table showing thermal conductivity of ethane, C2H6, at varying temperature and pressure - Imperial and SI Units. -
Online calculator, figures and table showing thermal conductivity of ethylene, also called ethene or acetene, C2H4, at varying temperature and pressure - Imperial and SI Units. -
Fiberglass Insulation
Thermal conductivity of fiberglass insulation - temperature and k-values. -
Typical heat exchanger materials and their thermal conductivities. -
Online calculator, figures and table showing thermal conductivity of hydrogen, H2, at varying temperature and pressure - Imperial and SI Units. -
Some fluids and their thermal conductivities. -
Metals, Metallic Elements and Alloys - Thermal Conductivities
Thermal conductivities of common metals, metallic elements aand alloys. -
Mineral Wool Insulation
Thermal conductivity - k-values - vs. temperature. -
Perlite Insulation
Pipes and Cylinders - Conductive Heat Losses
Conductive heat losses through cylinder or pipe walls. -
Piping - Recommended Insulation Thickness
Recommended insulation thickness for heating systems like hot water and low, medium or high pressure steam systems. -
Thermal conductivity of plastics. -
Polyurethane Insulation
Online calculator, figures and tables showing thermal conductivity of liquid and gaseous propane at varying temperarure and pressure, SI and Imperial units. -
Resistivity and Conductivity - Temperature Coefficients Common Materials
Resistivity, conductivity and temperature coefficients for common materials like silver, gold, platinum, iron and more.. -
Thermal conductivity coefficients for insulation materials, aluminum, asphalt, brass, copper, steel, gases and more. -
Thermal Conductivity - Unit Converting Table
Convert between thermal conductivity units - table and diagram. -
